Slightly off-topic PC question
Can anyone tell me what kind of specs I should be looking for in a new PC for optimum graphic performance - not just in CC3+/CC4 (when it arrives), but with ordinary graphics apps as well? I use GIMP and Krita, and 3D apps Sketchup and Blender to make new symbols.
«134
    As much RAM as you can afford.
    The most powerful processor (with the most number of cores) that you can afford.
    The biggest hard drive available.
    In that order, IMO, though others may disagree. With the Sketchup stuff, a more powerful processor might be more important (assuming it uses multiple cores properly).
    I'm currently holding out on upgrading my home PC for memory prices to come back down a bit more so that I can afford 64 GB of RAM to go with the four or six core Xeon processor. I would consider 3 TB the minimum size for a hard drive, and bigger would be better. (I'm planning on probably a 500 GB SSD boot drive, but all data will go on a regular hard drive, or two, or three, or five.) There are some pretty decent deals on 6 TB drives these days.
    (I have no recommendation on video cards, because I do nothing that would benefit form a fancy one, some of which cost more than my car.)
    Wow! That's certainly a lot bigger, faster, and everythingier than I was thinking.
    A friend of mine who draws maps in PS for a living just recommended this one - its within the £1000 limit, and leaves enough to get extra things, like a second slightly larger screen, and maybe a new and larger tablet.
    https://www.amazon.co.uk/Fierce-Legends-Gaming-PC-Bundle/dp/B07JGC79DW/ref=sr_1_71?keywords=game pc&qid=1555969541&s=computers&sr=1-71
  • pool7pool7 Traveler
    I would strongly suggest you get the components and either build it yourself or have someone you know build it for you.
    With branded PCs, you end up paying more, and in many cases they may not be as expandable in the future as one would think.
    Alternatively, if you must go for a branded PC, make sure it is expandable according to your needs.
    As for the specs, nowadays I'd suggest these as base:
    Core i5 (latest gen)
    16 GB RAM
    250 GB SSD (OS drive)
    # TB HDD (Data drive)
    (# based on your needs
    Of course, the more the better, especially for the RAM and processor cores/threads.
    Posted By: LoopysueWow! That's certainly a lot bigger, faster, and everythingier than I was thinking.
    And, I suspect, a lot more expensive, too. What I want would run about $2,700 right now. But memory is still kind of expensive, though it's coming down slowly. But that's why I said "as much as you can afford. :)
    The HP system looks pretty decent with a i7 processor, especially given your budget. (Does "Renewed" mean the same as "Refurbished" does here?) And a 2 TB drive will go a long way (and is fairly easy to replace/upgrade/add on) later, if you need more. 16 GB of RAM is about the minimum I'd mess with these days, but it looks like it could be upgraded to 32 GB later if you need it. As a computer intended for office work, it won't have a high end graphics card, but that, too, can be upgraded later easily enough if you need it (I doubt you will, unless you start doing real-time video processing).
    You might also take a look at Dell's refurbished site (under business - the home stuff is high end gaming machines and waaaayyy too expensive). It's a somewhat limited selection (it's a pity you don't have access to the US site, they have about 20 times as many items available most of the time), but if you're patient they should have new stuff there on a weekly basis. It might be somewhat more expensive, but it's refurbished by the factory that built it. I have a lot of experience with Dell refurbs, and they've always delivered as promised.
  • RAM is generally not too expensive, so start at 64 GB RAM. SSD is nice, but costly (I have two 1 TB SSD, cost ~ $A650 each). A good graphics card is important for your work. Anj external hard drive using USB is ~ $A160 for 3 TB, and if possible, I would definitely get one for back up of all your work. And the best processor you can afford.
  • Mind you, my current desktop, where I do most of my work, was bought in 2011, with newer graphics card and SSD hard drives. And it uses a much better system than Windows 10 - it is called...... Windows 7.
    edited April 2019
    Since money is an issue, I would plan for upgradeability, there are things that are easy to upgrade, and things that aren't
    Personally, I would prefer having 32 GB of ram (or more), but you do actually get quite far with 16 as long as you don't try to run a ton of different demanding programs all at once. If the computer only contains 16, make sure it has 2 8Gb sticks, and not 4 4GB ones though (most computers have 4 slots for ram, this leaves two slots for easy upgrade later without wasting anything)
    The system drive is somewhat difficult to upgrade, so it is best to have something there you will be happy with. Personally, I find 256 GB SSD's to be a bit to small, but again, since money is an issue, you should be able to manage with that, but I'd recommend a 512GB one, and preferably a NVMe drive instead of a SATA one, but in any case, the system drive should ABSOLUTELY be an SSD.
    Processor is very troublesome to upgrade, since new generations often require new motherboards, so this is the most important factor. Preferably, I would say go with an i7 (i7-9700), but you should manage with an i5 too. I am more familiar with Intel, but you do of course have the AMD option too. The downside here is that they usually have more cores, but have less per-core performance, which will hurt CC3+ (but may be better in other graphics software)
    A graphics card is easy to upgrade. While many graphics applications can take advantage of your graphics card, I wouldn't prioritize this highly for the initial computer. It can only help with certain workloads anyway, a better base computer is preferable in the beginning, you can upgrade the graphics card later.
    If you have a small SSD as a system drive, you will need a separate data drive. This is also easy to plug in later, so it is another good candidate for saving money. I would still probably go with a 1TB drive, but you don't have to go for the fastest one. Personally, I don't like HDD's in my computer, and prefer to go all SSD, but this is much more expensive.
    Either get a good monitor immediately, or get something really cheap that you plan to replace later. Throwing money at a medium-range monitor that you plan to replace is useless. And remember for graphics work, contrast ratio is much more important than latency, and get a matte screen, NOT a glossy one.
  • thehawkthehawk Surveyor
    Something else to consider is support when something goes badly. If you build it yourself, you're supporting it yourself; same goes for having a friend build it for you. If you buy a branded computer, then they will support it - how much and how convenient that support is depends on how much extra you're willing to pay.
    Another alternative is to research local dealers to see if there is someone that will build to your specifications and provide support for some period of time after.
    Thank you VERY much everyone :D
    A lot to absorb and consider, and I have to go to my course this morning...
    This site was recommended by one of the FB Group users as a good place for buying. Maybe someone here has used it before and can either condone or condemn it?
    https://www.scan.co.uk/shop/pro-graphics
    edited April 2019
    The major considerations for someone like me, who is terrified of being ripped off just because she doesn't know enough about anything technical, is that the machine is worth the money, can do the job properly, and if it breaks down will also be repairable by the same people who sold it to her without costing just as much as the initial purchase. (That last bit is a problem with the main high street vendor, PC World (or whatever they call themselves these days after the merger). I would do anything to be able to avoid ever using them again after they quoted me £100 just to clean my £300 laptop, but... would I take the extra risk of an online supplier?
    Also important update to the conversation - I had a brief flirtation with Amazon last night. For about half an hour I thought it would be a great idea to get one there, but on reading the highly conflicting reviews on the machines that interested me (16GB RAM, 5 processors, 2 different kinds of drive, etc) I decided against that idea altogether.
    Ok. I had a very brief chat conversation with Scan PC just now, and will call them in the morning to see if I can't shave a couple of hundred off the price of this one (the cheapest in the range) by swapping things out. They do custom made.
    https://www.scan.co.uk/3xs/custom/cad-graphics-workstations/workstations#anc
    It's got the 2 x 8GB RAM sticks, and... I'm not really sure about the rest. Its a bit confusing to me, so I will have to discuss it with them.
    Please - if anyone can see something about this rig that is a definite no-no - please say so?
  • RelytRelyt Betatester Traveler
    I was responding to your Facebook post but I am now over here.
    That’s an awesome set up, the only concern would be the cost, don’t forget to budget for your peripherals (keyboard, mouse, monitor etc).
    The Quadro is Nvidia’s professional line of cards. It’s going to be more geared towards graphic development vs gaming, so I think a good choice for you if you can afford it.
    The processor will be more than fast enough, I’m not a fan of overclocking as I want to make sure my parts last for a long time but if done right with proper cooling it supposedly can last just as long as a non overclocked cpu.
    Corsair’s RAM is some of the best quality you can buy which is great, you don’t want cheap RAM as it can cause hard to track intermittent problems. ASUS is the one of (I consider the) best motherboard brands out there, Samsung is a great SSD and HDD manufacturer. The only thing they don’t list is the power supply, I would find out which brand they use, I have never had a problem with Corsair or Antec, and I would avoid any off brand power supplies as it’s the life blood of your computer and a bad power supply can cause all sorts of problems including frying everything.
    Thank you, Relyt :)
    I feel a bit more confident about talking with them now. It seems that they tend to use good quality components at any rate.
    I think I clicked the Configure button and got confused as heck and backed out of it. I have just gone there again because I remembered seeing the power supply. The default is
    LN71877
    550W Corsair CXM, Semi Modular, 80PLUS Bronze - Single GPU
    In your personal opinion, do you think there is anything I could possibly afford to do without, or have a smaller, less powerful version to cut the cost down a bit?
    edited April 2019
    The first thing I would cut back on is the graphics card. They list a P400 as possible replacement, and that is over £100 saved there. Or you could go for the GTX 1050 which is slightly less saved, but far more powerful (The latter is a gaming card while the former is a professional card, and those are usually way more expensive without really giving any advantage to a normal user)
    Of course, it is a weaker graphics card, but the graphics card isn't your main thing here anyway.
    Thank you, Remy! :)
    I would be lost without you and Rely.
    I can see that I will need to have this conversation and the one over on the FB Group page open while I discuss the options tomorrow.
    Remy - that alternative graphics card? will it perform as well when I'm doing stuff in other apps - 64 bit graphics apps like GIMP, Sketchup and Blender?
    That’s a solid power supply. I really am more concerned about brands that have good quality control then I am about bigger specs.
    In my opinion, the first thing to dial back on is the graphics card, Quadros are expensive and most of your tools won’t make much of a difference vs a low end gaming card.
    You might be able to tone the processor down a bit as well, see what options are available. Looking at their configure tab it looks like to go cheaper you may have to step down to an i3 which isn’t ideal (but not the end of the world)
    I wouldn’t change the ram though (unless you get a deal for more)
    You and Remy seem to agree that the graphics card, though very nice, is possibly a bit overkill considering the cost and the purpose of the machine, so I will discuss that in detail with them. Hopefully there will be someone there who understands how graphics apps work and can relate that to the build.
    I currently use an i3 laptop. Never had any trouble with it until MS foisted that Win 10 monster of an OS onto us, and the processor speed just died on me when the security upgrades came out just over a year ago now. Since then I've been limping through everything at a yawn-inducing snail's pace. I need to be able to draw things at full scale and in real-time, not half the size I really wanted it to be and 5 minutes later. LOL!
    Are i3's more efficient now, or will I end up with the same kind of problem where speed is concerned?
    Remy beat me to it but yes, double confirmation.
    I’m not current with everything new but the things to consider: the current generation i3 should run circles around your old i3 and quite often laptop processors are a lot weaker then desktop to conserve power. So I would talk to the seller/builder and see the price difference to see if it’s worth it.
    The intel security updates that caused massive slowdowns were dependant on the processor generation, not if it was an i3/i5/i7. So a new i3 won't have that problem. Knowing what work you do, I would really advice against an i3 though, but of course, everything is down to what you can afford.
    Thanks, Rely
    This laptop is only 4 yrs old, but I know that's probably equivalent to 20 IT years because HP ceased support at the end of 3 years - just when Win 10 really hit me badly with their famous Creators Update.
    I will see what I can sort out, Remy. I would prefer an i5. I know I can't afford more than that, but if something has to give as well as the graphics card it might have to be the number of processors. And anything is better than what I have right now.
    I looked at their other choices for drives and it looks like you wouldn’t save much downgrading hard drive space, so unless they have some other deal offline it doesn’t look like much can be saved there.
    Here is the i5 and i3 side by side:
    https://www.cpubenchmark.net/compare/Intel-i5-8600K-vs-Intel-i3-8350K/3100vs3102
    Single thread is not much different (so cc3 would be fine on either) but the i5 takes off on the overall benchmark.
    The graphics card is practical to upgrade later on, when you can afford it. The processor is . . . not, really. In a real pinch, I'd skimp on memory before downgrading the processor, because it, too, is far easier to upgrade.
    Thanks again, Rely :)
    We shall see how it goes tomorrow when I call them. Maybe something in a different range would be better (not specifically set up to be a professional graphics machine I mean), but I doubt it. The average PC for sale out there right now only seems to be 8GB RAM, and not specifically set up to be able to store all that much above and beyond the family photo album. I have 500GB disk in this laptop, and I'm down to my last 80GB storage space. The backup disk I use is also only 500GB. I need at least 1 (preferably 2) TB storage and backup space. That's going to cost me, I know!
    edited April 2019
    Taustinoc - thank you :) It may well be that I will have to start with just 8GB RAM, but that is far far more than I can use right now. This machine has only 1.5GB RAM available to the user because of the mess Win 10 and the processor upgrades made of it. 'incompatible' with Win 10 is a polite way of saying it.
    Most of the slowness is caused by all the swapping that's going on. I live in fear of the drive packing up under the strain of it all.
    8 GB of memory is pretty standard these days unless you specifically go looking for more. You'll wish you had more, in all likelihood (I have 64 GB on my work computer, and I wish I had more), but it will be a lot better than what you have now. CC3+ won't use more than about 3.5 GB (being 32 bit software), but I presume most of the other stuff you use is 64 bit. You may run into issues if you're running several 64 bit apps at a time.
    I would recommend ordering it with the fewest number of memory sticks possible, preferably one. That way, you can upgrade to 16 GB by buying one 8 GB stick, instead of two to replace 4 GB sticks. Adding memory is a very basic IT task. Anybody comfortable opening the case should be able to handle it.
    By all means, get the biggest drive you can afford, but with a mini-tower sized case, it will probably be easier to add a second drive than to replace a small one. You then move all the data files to that, and keep the boot drive as clean as possible. (And that's only slightly more complicated than adding memory.)
    Brave enough to open a machine...
    Debatable.
    I hadn't realised it was one of those dinky little ones!
    That's good. It will fit a lot better on my dinky little desk :)
    edited April 2019
    Something to else consider with smaller cases is not only room for expansions, is also airflow and noise, and where the trade off is for you. Smaller cases means less space to put fans in, meaning that in order to move the same amount of air, they have to spin faster, so more noise.
    If the case is larger, there can be more fans and / or larger fans, so lower RPM, so less noise. One of my cases has a 120 mm fan on top and another one on the side, and it is ridiculously quiet; it is also ridiculously huge.
