3,238
Member
5,517
24
  • Community Atlas - Forlorn Archipelago - Fisher Isle, several villages and surrounding areas
    Not sure I've ever used the Blend mode, so am pleased Sue's already jumped in on that one.
    The three brown areas do have a very sharp line across where the sandy lower cavern floor cuts across them, which I assumed would be addressed later on. The downside with work-in-progress topics is I'm often not clear which items are more nearly finished in them.
    I'm guessing it's the general disconnect that you're finding problematic, with that darker piece each as well as the sharp dividing line where they overlie the sandy lower cavern area. Presumably, that wasn't what you wanted there. So you need to identify what the three areas are meant to be and where they are in relation to everything else nearby (higher or lower, or simply a different floor texture, say). That might give us some better ideas what to suggest to help.
    What I should have done, was start a Marine 2 dungeon map, then added DD3 Color dungeon items.
    I did the opposite. Whew. Big mistake.
    Live & learn, Jim...
    So, should I start a Marine 2 dungeon, and insert the below fcw into it ?
    You might find it useful to see this PF blog posting from a few years ago. Although it's dealing with creating battlemaps from a larger dungeon map, it does have relevance for what you've been trying to do here, I think. Only chanced-upon it yesterday myself, because one of the author's random-design products was the "Deal of the Day" on DriveThru RPG, and I was hunting around for more information, because he's made very extensive use of CC3+ in mapping for his products!
  • Problems with Text
    Try copying the text onto a new Sheet with no Effects on it in exactly the same place as it is now (so the two texts overlie one another). It may work better with the new text Sheet below the original (but still above the floor) or above the original text Sheet.
    Alternatively, you might try changing all the text's colour to something slightly different to what it is currently (because the "acne" effect seems to happen when there's something of an identical - or nearly identical - colouring on two overlying Sheets which have certain kinds of Effect in operation). In this case, it may be simply the text Sheet's Effect interfering with the specific colour and shape of the floor fill's patterning.
    LoopysueDak
  • Community Atlas - Doriant - Galahais - The Morstarik
    Yeah, I agree with Monsen regarding the text labels. There's also a problem that parts of the words on the paler text fade where they overlie the palest green on land.
    I get the impression too that the roads are on a Sheet higher than everything else, so look to be overlying some of the text labels as well.
    Might be worth tweaking some of the red dashed border line nodes to try to remove the odd long dashes in places, though this is a perennial difficulty and can't always be properly resolved, I know.
    I'm finding the dashed roads a bit distracting. Partly, this seems to be because the roads cross over the settlement circled-dot symbols, so that could be simply part of the Sheets issue noted above. However, I think it's also partly because the roads often don't pass through the centre of the settlement symbols. While that can be a legitimate point on a map (i.e. the main road may not pass directly through a settlement), at this scale, I think it probably should be tidied-up.
    JimP[Deleted User]
  • Community Atlas: Embra - Constructed Places
    Thanks very much everyone!
    And on Quenten's point, the odd thing is the Character Artist portraits take hardly any time at all, by contrast to other types of map.
    It is a shame that Character Artist doesn't get the same kind of updates and additions other parts of the CC3+ program suite do; some variant body and face shapes would be interesting, for instance, though I appreciate that would add a lot of extra work, fitting the various costumes and weapons, etc., to such alternate forms. Still, if you don't ask...
    JimP[Deleted User]GlitchTheschabiMathieu Gans
