Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
Invasion of Warlock
@Monsen That is what I did expect I did it the hard way. I adjusted the size and keep putting into the map until it was close. Never thought about putting the explosion symbol in the symbol file I was working on. My be the cold weather has froze my brain already.
I will say that I was able to use some of the tips I learned from you blogs and videos when working on the symbols. Thank You for those.
I have a set of symbols done now but not sure about how I have them sorted in the symbol file. I need to do the varicolor ones next.
If any experience symbol catalog makers would like to look over my symbol catalog and tell me how i can better organize it that would be greatly appreciated.
Community Atlas - Berenur - Temple of Aeniar
@Quenten It's the one I made using @EukalyptusNow tutorial. I just resized it from the one I posted in that thread.
https://forum.profantasy.com/discussion/12954/how-to-create-decorative-symbols-by-tracing#latest
Yes this was designed to go into the atlas. Later I will do a more detailed map of the island and the dungeon located on the island. Remy is waiting until the SS6 goes Gold before adding it to the atlas just in case somethings change between the current beta version and the release version. I will never catch you Wyren or Jim in atlas submissions but I do want a couple more atlas badges.
@Monsen Remy I found an issue with the text so I fixed it and here is the new .FCW file. Also added a glow to the puffin.
After seeing map in Blog found another text error missing stables - corrected and re-uploaded.
marble tile floor textures available?
Full Installation Almost Complete. I just need...
Links can be found here.
https://forum.profantasy.com/discussion/10443/free-symbols-artwork#latest
Mike Schley freebies
(WIP) Bindak's Retreat - An Asian Pirate Hideout
@JulianDracos Not strange at all. Where I live you see forest or heavy vegetation between barren hills in the valleys. It all has to do with latitude, weather, terrain elevation, tree line elevation, soils types etc. ie a lot of factors.
@EukalyptusNow Really nice map/ Love the fish heads
Winter Trail Project
My problem with the rocks is that the snow on the rock is too flat no texture, That would be fine if the ground cover was also completely covered in snow but that is not the case. There should be more texture in the snow on the rocks and the larger rocks need some of the rock showing through the snow more to match the other ground terrain objects.
Looking forward to this set of symbols but in real life I'm soooo tired of SNOW!!
Print Issue
