Legible text across a mountain range - any other way aside from putting a "gap" in the mountains?
Hello map enthusiasts and world builders!
I have a mountain range which I'd like to name, by putting text across the same area that the range itself occupies.
At the scales I'm using, the text has legibility issues even when I've activated the sheets effects.
Is there any way to put a "fuzz background" behind the text so it helps the viewer distinguish it from the mountains?
Or am I resigned to just deleting mountains immediately behind the text so it's against a more homogenous background?
