seven kingdoms
whit2468
🖼️ 77 images Surveyor
another map that im currently working on.
i really should try to concentrate on one map at a time
I have dozens going on, but I too should stick with just one. It gets done faster.
Ditto - I have 10 on the go - I try to do a bit on 2 maps at a time. It does stop me getting 'mappers block' though.
Hey whit2468,
Could you teach me how you are making these maps? LOL...seriously. I've checked your FCWs a time or two and I come up with the dreaded red Xs on a great deal of it. I am a graphic artist trained in photoshop and illustrator way back in the day, so are you using those progs?
thanks
Cal
hi, everything is done in CC3plus to produce the finished map.
I dont use the Annual Fenlon style for these maps. I use my own version, which i started making before that was released. though i did borrow some elements, so they could be used with each other. like the background and colour palette. This is still being developed and tweaked with each new map i start.
You are getting red Xs because you are missing bitmaps from certain locations. ive coppied the necessary images into my gallery.
Copy PF_B_Mountain directly into the folder below.
"C:\ProgramData\Profantasy\CC3Plus\Filters\Images\PF_B_Mountain.jpg"
For the bitmaps you need to create a new directory in the location below called Pete Fenlon B. then copy all the bitmaps into this folder
"C:\ProgramData\Profantasy\CC3Plus\Bitmaps\Tiles\Overland\Pete Fenlon B"
Your red Xs should then disappear when you load the FCW file
Thanks indeed!
I'll get this done asap, I assure ye
Cal
Hey whit
I've installed the bitmaps as you said, but it appears many are missing. Can you advise?
Also, the bitmap files are not named correctly in your gallery.
thanks
Cal
hi
the gallery has renamed all the files when they where uploaded. I cant see any way round this, so ive created a link to V3.5 of my fenlon style. You should be able to download everything you need.
the link is set to expire in a week
https://1drv.ms/u/s!AmKT8JyoeZCkiKkVho4fPLmxK6bRMw?e=wWwoxQ
the current state of my map
i know what you are thinking. #@#!! this map is taking a long time, for a copy of an existing map. unfortunately i keep starting new maps, whilst not progressing this one.
the map currently looks like this
I think we've all been there, starting new projects when we have this other one that is still waiting for us to complete it.
Yeah, I'm the poster guy for that.
