Missing Files?
Hey all
While attempting to use CD3, I notice when I right click on Symbol Style Toggle button to select the styles I want, there are 2 glaring absences:
CD3 Bitmap A Default
CD3 Bitmap B Walls
I can't find them anywhere. Did I delete them somehow? Did they not properly install? Do they NOT exist?
Please help
thanks in advance
Cal
CD3 Bitmap B Walls
Please help
thanks in advance
Cal
If they are not in those lists, it means that the symbol catalog settings for those are missing for some reason.
If you still have the symbol catalogs (you probably have, since deleting a symbol catalog setting does not automatically delete the catalog (or vice versa), so you should be able to open them manually using the open symbol catalog button and browse to @Symbols\Cities\CD3\Bitmap A/B and open it manually from there. (Not that CD3 A Wooden and CD3 A Default are actually the same catalog though.)
I can't remember if this is a bug the update will install, but if you haven't installed update 12 for CC3+ yet, you should.
You can also easily make new symbol catalog settings to point to those catalogs, getting them back in the list. See this command of the week entry.
Wall folder for B is there, but empty.
checking updates
thanks in advance
Cal
In any case, there is a new installer for CD3 for CC3+ up on your registration page. I suggest you grab that and simply reinstall CD3 using that. It is up to date with all fixes, and it is a complete setup, so it contains everything.
thanks in advance
Cal
Am I missing or misunderstanding a step in this process?
thanks in advance
Cal
Otherwise you could create a new symbol catalog yourself by importing the symbol images, but that won't set all the symbol properties and such.
I don't understand what I'm doing wrong here heh
Cal
I now have a new issue. Whenever using the Hide All button on sheets, the program crashes. I've tried various reinstalls of update12 with no change. Starting to become frustrating. Will do on the support ticket.
thanks
Cal
Reported as much as I could to Ralf via support ticket.
Cal
