CSUAC installation
![AKABigBlack](https://secure.gravatar.com/avatar/04ef29a6bb416f5444b20b03c75a1ef2/?default=https%3A%2F%2Fvanillicon.com%2F44965d8714aca5215c23989d057c8aee_200.png&rating=g&size=200)
now i know this has been done to death, but i've run into something different. since my reinstall, i'm redoing my CSUAC install. i'm doing this step by step, per directions, but have run across something i haven't seen before.
1. needed to create a "CC3" folder in my C:\ProFantasy folder
2. appended fcw32.imn
2. extracted "CSUAC_for_CC3_v3.zip" into the new CC3 folder
so theoretically, i should have my menu buttons(i do), and access to the .FSC files, right(ex - C:\ProFantasy\CC3\Symbols\CSUAC\CC3_CSUAC_Animals\Aquatic.FSC)? no red x's though(i haven't extracted art yet), i only have blanks where the symbols should be. what's the deal here? i don't recall it being this difficult before....
The bL folders have the PNG files and the CC3 have the *.FSC files
Ken
This is monsens comments on this issue
MonsenCommentTimeJan 6th 2009 whisperquote
Posted By: freefallin
and yeah, it is an immediate error
Ok. That means that it can't find the .mnc files, so let us forget about the symbol catalogs themselves for now (The fsc files)
- First thing to try is to try several of the buttons, and both left and right click on them. This establishes if there might be an error in the fcw32.imn file. If some work, and some doesn't, you should redo this file.
- If all the buttons create errors, check your file structure.
1. Make sure you have a subdirectory called "menu" inside your main CC3 directory, and not inside a subdirectory or anything
2. Make sure you have copied the 8 *.mnc files directly into the menu directory, and not inside a subdirectory or similar.
3. If you are using Windows Vista, it is sometimes a bit protective about the content in the Program Files structure. You can verify that CC3 itself can see the files by using file->open, browse to the "menu" directory you created, and manually type in *.* as the filename and hit enter. If the files are available, you will see them listed in the window. (Don't try to actually open them in CC3)
No extra lines top or bottom
#701,CAMONSTER2:[Creatures]{|CMENU #menu\csuac_creatures.mnc;}|CMENU #menu\csuac_creatures.mnc;
#702,CC2DRAWTOOLS:[Equipment]{|CMENU #menu\csuac_equipment.mnc;}|CMENU #menu\csuac_equipment.mnc;
#703,SS3VEHICLES:[Vehicles]{|CMENU #menu\csuac_vehicles.mnc;}|CMENU #menu\csuac_vehicles.mnc;
#704,SS3PEOPLE:[Animals]{|CMENU #menu\csuac_animals.mnc;}|CMENU #menu\csuac_animals.mnc;
#705,CAHEADTOG:[Humanoids]{|CMENU #menu\csuac_humanoids.mnc;}|CMENU #menu\csuac_humanoids.mnc;
#706,CC2VE:[Vegetation]{|CMENU #menu\csuac_vegetation.mnc;}|CMENU #menu\csuac_vegetation.mnc;
#707,DD2FURNITURE:[Furniture]{|CMENU #menu\csuac_furniture.mnc;}|CMENU #menu\csuac_furniture.mnc;
#708,PERIHOUSE:[Structures]{|CMENU #menu\csuac_structures.mnc;}|CMENU #menu\csuac_structures.mnc;
If your CC3 runs fine that is no problem in itself. Just make sure you place all the CSUAC files and folders directly under /Profantasy/, instead of creating the CC3 subfolder and placing them there.
a huge thank you to everyone who has had the patience to help me through this(again). trust me, this WILL NOT HAPPEN AGAIN.
