Selecting Command
IthrilIthril Traveler
Just a quick simple question...
Is there a 'Select All' command that I can use to select everything on the chosen layer and sheet (assuming all other sheets are hidden, and all other layers are frozen).
I'm trying to clean up one map to use specific entities on another map, but I need to eliminate all the extraneous unneeded layers and sheets; but I can't do that without eliminating all the other objects on the chosen sheet and layer.
Thanks !
PS: I still LOVE this program. I get lost using it, and time just flies by. I'm planning on updating my annuals purchases shortly. 😁
