I think that will do the job. I’ll move the colour wheel and edge lines to separate sheets, that will give the definition Im after and not affect other symbols that should be on the Symbols flat sheet. I’ll make some sheets for the highlights and shadows for the depth.
At its actual size in the drawing that should look pretty good.
Here is my "rainbow coloured, ice-cold floating gem" in situ. This will have to do, as I need to get these maps finished - they've been dragging on far too long and once I finish this one, there's 2 more to go. Thankfully, they're both much simpler.
Last update before I finish this bad boy, I'm on the home stretch...
Sorted my Gold and Silver leaf fills, downloaded the textures from Sketchup and did some fine tuning in Affinity Photo before adding them to the Bitmap folder and importing them.
Added a'glow' to the gem, might play around with the blur and transperency settings for that, I think it needs to be a bit 'softer'.
The second image includes the hand drawn sketch I'm working from...
NOTE: All images Copyright of Crusade of Steel 2023.
Thanks Joe,
Hi Folks,
