Forgotten Realms Interactive Atlas repairs.
123457»
  • 16 days later
  • I have some free time, so I am going to try finish my project.
    Goals.
    #1 Create an install list. Which files to pull from which update.
    #2 Link missing maps. Not too many of these.
    #3 fix the broken links with a description how to fix each.
    #4 add in missing links. These are completely missing hyperlinks. Which are different than broken links, which are essentially typos in the map file hyperlinks.
    Thanks again to everyone who's helped along the way, and those who have shown interest.
  • I have the install order 99% complete.
    There is a major problem with three hyperlink trees. Blackfeather Bridge, Archendale and Featherdale.
    If I remember correctly some of them are named wrong and need to be sourced as to which is correct.
  • According to my notes...
    For Blackfeather:
    CD & Up1 shows a teaser put at the time to avoid spoilers.
    Up2-3 show the bridge itself and surroundings.
    And my edit proposal:
    Rename the one from CD or Up1 to "10020 Blackfeather Bridge Village.FCW".
    Add a link to this new map from Featherdale.FCW
    Add a text link between the two 10020 maps.
    See this comment for more info on Blackfeather.
    For Archendale, I think this is your edit proposal:
    Change Nairning to Fall's Creek and Ramblecoats to Arkhenham (both labels and links).
    And for Featherdale:
    Change labels from "Black Feather" to "Blachfeather"
    (again, this is probably your suggestion)
    That's all I got. Did you find something else missing?
    Anyway, I'll also upload my XLS tracking, in case it's useful:
    Do note that I usually have a filter active (on column I) to hide map that are identical in all 4 versions.
  • Yea I sent an email to a group Ed Greenwood is part of to confirm the mis-named maps for Nairning and Ramblecoats. Just awaiting a response. If anyone would know it would be he.
    10 months away and a person tends to forget a bit. Considering it's 850+ maps.
    roflo1
  • Here is the first major walkthrough on the repairs. Phase 1-4. Phase 5, 6 & 7 will be once I complete the repairs and walkthrough. Those will be fixing broken links. Fixing missing links. Linking missing maps. (each is different due to repair method)
    This repair changes the Atlas with all updates from 600 maps to around 750. There were so many broken hyperlink trees that make about 150 files unable to be accessed through using the atlas. Once all the repairs are done the Atlas will be able to use the 850+ maps.
    Phase One
    #1 Install Forgotten Realms interactive atlas in default folder.
    #2 rename file 10020 black feather bridge to 10021 blackfeather bridge found in the maps folder
    (default maps folder C:\program files (x86)\FR atlas\Maps)
    Phase Two
    #1 install Update 1 into default directory.
    #2 create a folder on desktop name it FRIA recovery or something you will remember.
    #3 cut the following files from the default directory (default maps folder C:\program files (x86)\FR atlas\Maps) folder and place them into the FRIA recovery folder
    0070 Amelior's Workshop.fcw
    0080 Secret Cave.fcw
    0090 College of Rune Magics.FCW
    0100 College of Shaping Magics.FCW
    0110 Mount Drakkor Rouge.FCW
    0120 Temple of the Dragon Oracle.fcw
    0130 Border Outpost.FCW
    0150 Adzerak's Home.fcw
    0160 Thistleflame Keep.FCW
    0160 Thistleflame Keep-Manor.fcw
    0180 Journey's Rest.fcw
    0200 Tower of Ruin.FCW
    0210 Wyvernwatch.FCW
    1140 Macoley Farm.fcw
    1270 Mage-Lords Crypt.fcw
    2170 Khazari Ra-Khati House.fcw
    3590 Zhentil Keep post 1368.FCW
    3820 Azatl.FCW
    3981 Dagger Falls.FCW
    4080 Elmwood.FCW
    4160 Eveningstar.FCW
    4220 Helmsport.FCW
    4330 Ixtul.fcw
    4360 Kuo Meilan.FCW
    4430 Manass.fcw
    4530 Michaca.FCW
    4750 Raven's Bluff.FCW
    4850 Shadowdale.FCW
    4950 Suzail.FCW
    4970 Tantras.FCW
    4971 Tantras 3D.FCW
    5390 Waymoot.fcw
    5390 Westgate.FCW
    5450 Yulash.FCW
    5470 Zhentil Keep.FCW
    6600 Thri-kreen Village Below Ground.fcw
    10024 Heggar's Bridge.FCW
    B1dNElc.FCW
    #4 rename file 10005 Arkhenham.FCW to Ramblecoats.FCW
    #5 rename file 10006 Falls Creek.FCW to Nairning.FCW
    Phase Three
    #1 install Update 2 into default directory
    #2 cut the following files from the default directory (default maps folder C:\program files (x86)\FR atlas\Maps) and paste to FRIA recovery folder.
    0220 Undead Castle.FCW
    0230 Yeoman's Loft Bank Interior.fcw
    0240 Polaris Vault Interior.fcw
    1960 Arnagus the Shipwright.FCW
    30005 Aru.FCW
    30138 Catacombs of Moradask.FCW
    B1cNWlc.FCW
    Sembia.fcw
    Phase Four
    #1 install Update 3 into default directory
    #2 Cut all files from the FRIA recovery folder and paste to the maps folder in the default folder
    (default maps folder C:\program files (x86)\FR atlas\Maps) may need Administrator permissions.
    Monsen
  • Don Anderson Jr.Don Anderson Jr. Surveyor
    edited April 2024
    Great night deep diving into some unknown items/maps within the updates. There are an additional 11 maps that I can add into the Forgotten Realms Interactive Atlas.
    I'm pretty happy, a ton of research to find the areas to link these maps. I'll add these gems shortly. Means more work, but a total surprise going down that rabbit hole.
    MonsenRalfroflo1
  • So here are some of the unknown maps I have come across. I have absolutely no idea how I have come across them.
    6 of them are not realms related the 4 bandit ones, blue sword inn and perClangeddin. The other 10 all look like official maps.
    2 are copies of actual maps Arabel is the Hieronymous bosco map, and house black hand is the same.
    If anyone has any information on these maps I would dearly love it.
    I also solved a huge mystery of broken links with the Desert of Desolation maps. The Garden of the Cursed map had a link so small it was essentially invisible. On my 65 inch 4K tv it was 1 pixel wide. It is at the very top of the map by "final doors" With that link found the whole map sequence now makes sense.
    Going to test my maps tommorow. Every single, broken, missing and mislabled map has been repaired. I have also created map up hyperlinks on all the maps I have found that were missing them. Could be all 855+ maps are now working 100% Researching 46 unknown maps was such intense work. My old Forgotten Realms Atlas came into use for easily a dozen of them.
    I think at the start of this project a person could only get to 500 maps through the hyperlinks. That was due to bad versions of maps that overwrote good versions. Some maps were eliminated. Then lots of updated maps missed links that were on other earlier maps.
    Traveller
  • Checking links
    441 maps fine
    1860 links so far. I am curious how many links in total there will be for the entire atlas.
    Down to level 3 maps.
    Once I get to waterdeep that will be a chore
  • 12 days later
  • 851 maps
    3600 links
    100% connected
    Alby87
  • In the last few weeks I started converting all the maps to CC3.
    Wow I wish I never started. What a massive project. Moving all the sheets around to properly display the maps is a REAL pain.
    Some are easy, but others have their entities on the entirely wrong sheet. SO hiding and revealing sheets is the only way to properly line them all up. Quite often I would have to change properties of the entities and put them on other sheets.
    Got down to 200 maps left. Then the convert to CC3 screwed them right up. All the main world maps. It them mixed tons of stuff onto the MISC layer. Some text is text, some text is converted. So using a command to move them would only move some of them. Oh and this left outlines everytime. That was horrible.
    Then I had a Big Brain moment (As my daughter loves to say)
    Before the conversion I hid all layers except text.
    Convert the file to CC3+
    Then Change Properties on all the text and entities that were converted from text. Move them to the Text sheet and done. Then I could move all the sheets around so the map goes back to normal. What a ton of trouble shooting. Glad for the Manuals and Tome to try give me different ideas on how to fix stuff.
    I don't recommend anyone to convert all these maps. Way to much work. If you want a few or something it's ok, anything more than that and you will go a bit mental.
    Monsen
  • 1 month later
  • This means we can work on that automatic patch? If you have completed your work, I can start mine if you give me the resources :)
  • 2 months later
  • Will phase 5 6 and 7 will be released? If I have the instruction to build a 100% working and linked set of map, I can create that automatic patcher I was talking some months ago :)
  • 5 months later
  • FrostyFrosty Surveyor
    I need to review this entire thread as I got the wild idea today that I wanted to update my copy..these are fixes looks like here but was thinking of going further than that for personal use.. I wish there was a way of saying this is what it looked like in 1200 Dr and 3000 DR or age etc
  • There are a few maps that are of different times. I think Zhentil Keep has a few.
    I know I want to go through every single map and make them look more modern, but that will take eons.
    Aye, for me I would 0nly do it on my install where I needed something new and of course if I can figure out to share what I do in a logical way share it with the community. I have lots of "modern" maps just not in CC format :-)
  • The idea was to create a patch to implement Don's fixes without redistribution of the copyright map, and I've already made one that does phases 1 to 4 of his post. If he releases the remaining phases, or just his modified files to me, I will make the binary patch and release it. No need to update to CC3, just all the hyperlinks fixed would be fantastic!
  • I will leave this in hiatus until CC4.
    I'm not sure if I will let anyone access my files, due to the hundreds and hundreds of hours I've put into fixing everything and then converting them all to CC3. Believe me that was a massive undertaking, relayering every one of the 850 maps manually. When it converted the layers became randomly mixed up. I had to go sheet by sheet to correct them so everything would display properly.
    So now every map is CC3+ and 100% of all links work and every one of the 850 maps is correct.
    Frosty
  • I was thinking more of the CC2 version of the maps, the ones used by the atlas, not the updated CC3 ones. I hoped you would have released those fixes, and proposed you a way to release them avoiding any copyright infrangment. Maybe there was a misunderstanding.
    Oh wow I imagined it was a huge effort..but I did not realize you were updating format or honestly what is involved in that. I knew you were fixing links. Maybe this weekend I will have time to walk through the entire thread and see were the CC3 version of these are. Right now I have base atlas installed with patches from the site.
  • Getting all the correct files in order is a huge difference on how the interactive atlas works.
    I think if you only use the disc you are at only 400 or so maps. Once you add in the updates it really enhances the whole thing. Getting you close to 750 - 800 usable maps. The last 50-100 take a bit of work to fix.
    I hope it all goes well and you get so much more joy out of this awesome program.
    Frosty
    I am guessing since my install has 800+ CC3 drawing files that the updates I ran a while back were in fact your work Don as I understand from the above if not I would only have 400+ maps
  • After installing all the updates without doing any of these repair steps you lose a bunch of maps. The problem lies with how many bad maps were installed in place of good maps.
    In an earlier post I made a list showing how many maps you had access to after installing the updates. Taking note, that this adds in broken maps.
    cd like 400 ish
    update 1 650
    update 2 700
    update 3 800+
    I think the math was 80 wrong maps. give or take, plus all the broken links.
    Can't believe how this snowballed by someone noticing I had a map with no links, and they had one with the links. Then having to go through all the maps, through all the updates.
    So happy there were so many people that came together to figure it out.
    Got it so I would need to uninstall and reinstall following the repair steps. That many maps not including the link repairs is a ton of work.
  • Yea, because the updater writes over the good maps, replacing them with bad maps.
