Watabou City REVISED (annual 157)
2
  • edited May 3
    Some more drawtools. All work with the change drawtools command as well, on appropriate lines or polygons.
    Not sure why the fence didn't show so well on the jpg, when it did on the fcw. It may need work
    MonsenRoyal ScribeLoopysueCalibrethehawkjmabbottRaiko
  • I am having difficulty with my DOCKS Drawing tool. Mainly with the polygon version. I want there to be posts along the docks, but also want the fill (which is planks) to be aligned using Shaded polygons.
    All works well with the macro turned off. BUT ... when the macro goes on again, the posts disappear (sort of) and in the list command, instead of appearing on the DOCKS POSTS Sheet, they are now on the DOCKS Sheet along with the docks themselves. Obviously the docks macro needs revision, so it applies only to what is on the DOCKS Sheet, not the DOCKS POSTS Sheet.
    HELP!!!!
    Your macro looks a bit off. You have a select by prior instruction in there, but then your first argument to SHADEPOLY is what looks like a layer name. Did you intend to select by layer? (In which case, your docks and the posts are both on the same layer.)
    Also note that select by prior can select more than one entity. It either selects the same entities (all of them) that was int he last selection, or if you have drawn anything in the meantime, the last thing you drew, which in the case of a drawing tool with an outline will be BOTH entities that tool drew.
  • @Monsen So what do I put in to make it select by sheet? I am hopeless at macros - can you help out here and write a correct one for me? I gather I need to delete select by prior, but what do I put to select by sheets?
    And is there anyway to align fills when they are used as lines of a non-zero width? especially useful in cobbled roads etc
  • Here is a revised version of the Drawtools. so far, they all work with the Change Like Draw Tool command, including the towers and fields, which was not the case in the original watabou annual.
    A bit more work needed on the effects to get it all to my satisfaction, but I think the drawing tools are now ready to go.
    I guess the next step is to do an example map.
    I need to work out how to revise the scaling of the Hatch files, and how to make sure they are imported into the style, so people can access them if they need to alter the dimensions etc
    Royal ScribeCalibreroflo1Raiko
  • The example map I will be using for the upcoming revision annual for this style will be based on this city, which I have been asked to do.
    I will aim to use all the drawing tools.
    I will also go step by step through the process, so you can all comment (and correct) as I go.
    And for fun, here is a picture from the JSON export, to show a 3D version. Who knows, perhaps one day, we can work out a method to export the 3D versions to CC3+!!!
    Royal ScribeCalibreDon Anderson Jr.Raiko
  • The first most important thing is to just export as a SVG the actual elements you want and cut out all the pretty stuff. It is, after all, the street and building layout that we really want.
    So ... in the generator, first check colour - make this either B&W, or Ink in the Presets.
    Next, click on Style in the generator, and make sure you check or uncheck the following. Whatever I don't mention, you can choose as you wish.
    1. GRAPHICS: Check thin lines, leave the rest unchecked.
    2. ELEMENTS: Districts Hidden. Check scalebar only (if you want it, leave the rest unchecked
    3. BUILDINGS: Roofs plain, leave Raised unchecked. Otherwise, choose what you want.
    4. OUTLINE: Check buildings, and UNCHECK water and roads. They will seem to disappear, but will be present in the SVG and thus DXF
    5. MISC: Check Solids; Uncheck Show alleys and Show trees.
    6. FARMS: Choose plain. Though you can exclude farms if you like and use drawing tools provided to put them where you want. However, the drawing tools will work on the farms if exported as Plain.
    7. For those interested, you can get the number of buildings and suggested population if you click on SETTLEMENTS. However, I think the population does not take into account density of population, nor multistorey buildings, so the population levels for larger cities can easily be double the suggested number in the generator.
    As you can see from the example map, I have done all that.
    Now export as SVG (and Png if you want).
    Royal ScribeCalibre
    Unfortunately, there isn't a selector for select by sheet, but you can select by layer by using SELBYL.
    Unfortunately, that option is not straight forward when used in drawing tools, because when you select by layer, you select everything on that layer, including previously drawn entities.
    I guess the best option to handle that is to have the drawing tools set up to draw on a temporary layer that is kept empty, and then you can select the entities just placed on it, do the required manipulation, and then finish off with a Change layer (CHANGEL) command to move everything to the real layer.
    Unfortunately, no. You'll have to use polys for everything you need aligned fills with.
    roflo1QuentenRaiko
  • The next step is to convert the SVG into a DXF. I use the tool mentioned in Annual 157:
    Cloud Convert: SVG to DXF | CloudConvert
    Open a map in the Style Cities >Annual Watabou City Revised. (When it comes out). For cities, I estimate the size using the scale that comes with the generated map as a guide. The scale in the generator is in Metres, so multiply by 3 to get feet (a rough estimate is all that is needed).
    The example map is about 1000 m wide, or about 3000 feet. Against my long held principles, I will do the example in Imperial measurements, to cater for all you imperialist lackeys!! 🤣 So the map will be 3000 wide x 4000 tall.
    Make sure the Layer is set to 0, and the Sheet to IMPORT.
    Use Draw Menu, Insert File, to insert the DXF at origin 0,0 (the default).
    Right-click the scale button and choose Non-visual Scale. Right-click on the map to open the selection menu and choose Prior. The just previously placed import is now selected. Right-click again, select Do It and enter a scale factor of 5-10, or whatever seems appropriate to fill the map with the city. The previous annual showed the DXF as a small Dot, and required a scale factor of 400, but the revised version shows the DXF much larger, and requires a bit of juggling to get it just right. Make sure you scale origin is still 0,0 though. The map should now appear, roughly matching your drawing area, with some of the entities extending beyond the map border.
    Here is the map of Lowrock with the dxf imported onto the IMPORT Sheet, 0 Layer.
    And here it is, rescaled non-visually by a factor of 10, and then moved, non-visually, up a bit on the map to centre the city better.
    MonsenRaiko
  • edited May 5
    Now you must convert EVERYTHING (except background, Map border and screen, of course) from Line to Path (right click the Explode button on the left hand side of the screen).
    You will get something that looks like this!!
    Ugh!
    Monsen
  • Now for converting this mess into proper objects on the correct sheets and layers using the Change Like Draw Tool command (right click Change Properties button on the left-hand side of the screen).
    However, for each entity that we will change using the Drawtools, we MUST first set the correct Sheet and Layer. This is very important.
    Here I have converted all the water - the River, the sea/lake and the bit that connects the river to the sea (estuary). First, I changed the Sheet to Water/Rivers; and the layer to Water/Rivers. I don't need to change anything else.
    Second, I clicked on Change Like Draw Tool, and left-clicked to bring up the Draw Tool I want to select. I chose the Water Tool - straight, and then clicked on the entities to be changed - in this case the sea and the estuary.
    I repeated the process, only this time chose the River 50 and selected the river.
    Hey Presto - water finished.
    Next I did the Roads - here there is only 1. So, first, change Sheet to Roads Paved, and Layer to Roads. (If you don't want paved roads with cobbles and no Edge Fade, then just set the Sheet to Roads). Then use Change Like Draw Tool command, pick the appropriate Drawing Tool (here I picked Road, Paved 10), then select the entity - the line representing the road.
    Finally, at this time, I put in the Scale - for this map, I selected the Imperial Scale (<shudder goes through me> - LOL), with the size as 6. When I place the symbol, it asks for a number, and I type in 600. As you can see, it is nearly the same as the scale imported from the DXF, which is 200 metres. Not totally accurate, but good enough for me, and it measures 600 when checking with the Distance Tool.
    Here is the map so far:
    To be continued!
    Royal ScribeMonsenRaiko
  • I have now converted all the IMPORT into the appropriate sheets using the Change Like Draw Tool Command only.
    Remember to set the correct Sheet and Layer for each Change like Draw Tool command.
    eg Rivers and Seas (Lakes): Sheet WATER/RIVERS, Layer Water/Rivers
    Roads and Squares: Sheet ROADS or ROADS PAVED, Layer Roads. Note that Square Paved cannot be used in Change Like Draw Tools since it has a macro attached. I may change this later if I can find a paving that doesn't need alignment.
    Parks: Sheet PARKS, Layer Vegetation.
    Docks: Sheet DOCKS, Layer Docks
    Walls: Sheet WALLS, Layer Walls (Note: I have done away with the City Wall Layer). I am still not happy with the crens for the walls - now they hardly show. I will fix that.
    Towers: Sheet TOWERS, Layer Walls. No longer need to draw these without the Change Like Draw Tools command. And it means no guessing as to the size required.
    Bridges: Sheet BRIDGES, Layer Bridges
    Fields: Sheet FIELDS, Layer Vegetation. The furrows align to how the generator drew the fields. So often, not a very intuitive direction. However, if you want to use the tool directly to draw fields, the tool does align the furrows (which are Hatch symbols) correctly. In the picture below, I have done this with the bottom right hand field.
    Buildings: Sheet SYMBOLS BUILDINGS, Layer Buildings, or any of the Building layers you wish to use, eg Bldng (House 1)
    I generally advise doing the Buildings last, as you can then Hide all sheets except Import and Symbols Buildings (with the latter being the selected one). This will then show only the buildings you need to convert.
    I have also added buildings on top of the Palace, and smaller towers on the towers around the Palace.
    Comments and suggestions really welcome.
    Royal ScribeMonsenCalibre
  • The final step is adding all the extra bits and pieces - forests and trees, wetlands, roads and squares and city backgrounds, hills and contours, maybe extra buildings, buildings and towers on top of one another, even a gatehouse to replace the open walls in some places. And text and scale and compass, of course.
    Here it is, partly completed.
    MonsenTravellerjmabbottCalibre
  • 15 days later
  • edited May 21
    I have decided on another map for the annual sample. I am now able to include alleys and trees in the conversion process, so feel free to add trees and alleys to your generated maps from Watabou.
    This is the map I generated from Watabou, including emblem, trees and alleys. It was called Low Rock, which translates to Craig Isel in Welsh, so I am intending to go for a Welsh feel with the names. And the industry will be some sort of iron-working industry, as per the coat of arms.
    I have outlined the roads to show them, but in the SVG export, I have unchecked outlines for all except BUILDINGS. I haven't got any fields, so will use Drawtools to add my own.
    Here is the result after complete conversion, all using Drawtools, except for the emblem (which I also exported from the generated map).
    Here is the sample map so far, using Drawtools only, apart from text.
    LoopysueMonsenRoyal ScribeRaiko
  • PLEASE give suggestions or criticisms. I want this map to reflect the tools, but also to look like a decent map.
    edited May 21
    Ok. I think it's coming along pretty well. The main thing I would adjust if I was using it myself for a map is the hills. I would use effects and settings similar to those found in SS5, though I adjust those to make the bevel lighter again than it is in the template.
    The HILL sheet uses polygons of "Solid 20", and my personal settings for the Bevel, Lighted sheet effect give the hill a highlight as well as a shadow. It's personal taste, of course, but I find the template setup makes the hills a little too dark for my liking.
    These settings also use a lot more smoothing than you have in your template. It gets rid of the knife edge ridge which feels a bit unnatural for a relatively small hill - unless they are meant to be mountains.
    Having sufficient edge fade on the hill after the bevel also helps to make the hill look like it's a rise in the ground, rather than something stuck down on top of it - a curve into the slope rather than a sharp line, or a line that hasn't been faded enough with a wide enough EFI. I increase mine from 10ft to 15ft, though it could be wider.
    Royal ScribeQuentenRaiko
  • edited May 21
    The Hill shade is Solid White 20, so I will try those effects out - thanks heap, Sue - that is the sort of comment i am looking for.
    Just fixed it, and the result is much better. Thank you.
    Royal Scribe
    SS5 uses the black "Solid 20", but if it works for you with Solid White 20, you're welcome.
  • Solid black 20 worked better.
    Royal Scribe
  • I have decided on another map for the annual sample.
    Wait, does "annual sample" mean it's confirmed that this will be one of the future annuals? I hope so, because it's really cool but the macro discussion felt over my head and made me nervous.
    With the hills fixed, maybe look a bit at the fills. Right now, there is a lot of repetitive tiling, both the land and the water.
    Personally, I would also have worked the water shape a bit. I know this comes from the original generator, but that harbor with the overly straight north and south side of the water look unnatural.
    Finally, have a look at the legend. These are always a bit tricky, simply due to the way truetype font scaling works, but there are steps that can be taken to mitigate the problem. I would probably also right-align the actual numbers, avoiding that the gap between numbers and text change as you go to 2 digits.
  • I would die for a 3d conversion. That has been a dream of mine for my fav fantasy city for 25 years. I was going to teach myself 3d modeling, but there are so many other things in line ahead of that.
    Royal Scribe
  • 7 days later
  • Here is the final draft (repeat, draft - feel free to add suggestions) for the example city for the July Annual.
    I have completed all the drawtools and instructions to my satisfaction - just waiting for @Ralf to return from his well-earned holiday to see what he says. I am also going to add a plain version of the wall and tower buildings, but this will make the drawtool list quite long.
    It has been quite a journey, being able to take the new version of the Medieval City Generator into a form which can be more or less easily transform into a format that CC3+ can use. I was really pleased to be able to add the trees, alleys and even more simple versions of the Coat of Arms to the mix.
    The bitmap resolution still is not totally satisfactory - but if I make it too large, then the result looks strange, and if smaller, even more tiled. Grrr. And finally the hatch symbol for the fields at the top right are too fine, I think - not enough space between them for a city this size, but I am unsure how to scale them so they work better. And also how to get them to show up in the Symbol Fills list. I guess Ralf will help with this on his return.
    I might also do a much smaller settlement, but use the plain style, to see which people prefer.
    This is the first (probably only) annual style I have done, and I am a nervous wreck - haha I really take my hat off to those like Sue who produce such magnificent annuals. Thank you Sue amd Remy for your helpful suggestions - jsut having difficulty with the fill resolution size.
    I forgot to fix the legend as per Remy's suggestion. Rather than redo it just for this correction, i will post the final map when all the suggestions have come in. I want to turn everything in by 3-4th June.
    LoopysueRoyal ScribeTravellerMonsenRicko HascheDon Anderson Jr.RaikoGeorge
  • I am very much looking forward to this release. Thank you for all of the hard work you’ve put into it. Do you know when it’s scheduled for release (if you’re allowed to say, of course — totally respect that they might not want to announce schedules).
  • July is the date we are working to.
    Royal ScribeRaiko
  • edited May 30
    Here is a map done - took 45 minutes from downloading the SVG to this product - no text of course, but still, a quick town for adventure. And it gave me a chance to test, yet again, the tools I have used.
    LoopysueRoyal ScribeRicko HascheGeorge
  • Read through this whole thread....fascinating. AWESOME work and dedication to this.
    I think I played with this generator a long long time ago. (in my brian like 20 years) I think it could do really small settlements of three sizes.
    It all looks fantastic.
    I do have one question though. Is there an annual that can convert poly's to actual buildings? I have a bunch of maps that I would like to have look more like city maps rather than a few thousand open poly's. I am trying to do one of those cities with Symbols, but when doing thousands of buildings, scaling, rotating, placement and colour changes take forever.
  • I understand the tedium of making a city with house symbols for thousands of buildings - at least Watabou provides the placement of the buildings. if you use the house tool, rather than symbols, except for a few buildings, then that reduces the labour of scaling, rotating etc. I am already doing that using Darklands city for one of my Watabou cities, which I will show on a thread on the forum later.
    And thousands of buildings is what I did for my extravaganza city, Dun Fingolfin, which is now in the Community Atlas.
    Royal ScribeDon Anderson Jr.
  • I have revised the explanatory notes for the coming annual, and am using this town as the example. this is the completed map - well, it will be unless I get comments that I need to take note of.
    LoopysueRoyal ScribeMonsenMapjunkieroflo1LoreleiCalibre
