Very odd but persistent problem in Campaign Cartographer 3+ on Windows 11
edited September 2023 in Community Support
Hey folks! First time posting.
I enjoy ProFantasy's products and have for many years. Recently I've been getting more into Campaign Cartographer 3, after having spent many more years playing around with Fractal Terrains. I recently completed a map for an RPG campaign I'm working on that I'm very happy with and which encourages me to use the program more.
However, I have suddenly and rather inexplicably run into a problem. Merely having CC3+ installed on my laptop (Windows 11, Lenovo Legion Pro) appears to cause File Explorer to crash... repeatedly. Without end. Until I uninstall CC3+.
I at first thought the problem was a graphic driver issue or possibly something that had been installed on my computer recently. But I've done no fewer than three clean re-installs of Windows 11 from scratch to no avail. The only thing that reliably, for sure removes the problem is uninstalling Campaign Cartograph 3+. And when I try to reinstall it, shortly after it finishes the installation process the problem crops up again, causing Explorer to crash until, once again, I uninstall CC3+.
This is quite frustrating and more than a bit puzzling. I can't think of any reason why CC3+ would be causing the issue, especially since it doesn't seem to matter whether it is running or not only that it is installed. In pretty much every case where Explorer was crashing, CC3+ wasn't running, not even as a background application, but nonetheless its presence as an application on my hard drive seemed to force Explorer into its recurrent crash cycle.
At the moment, the only thing I can think to do is to either install it on a completely different machine (and who knows if that would cause the same issue or not) or try partitioning my hard drive with another version of Windows or something like Linux and trying to run the program on that instead.
In any case, since this appears to be a CC3+ compatibility issue with Windows 11 or Lenovo Legion Pro hardware rather than something specific to either of those I figured I'd post here in the hopes that somebody has some idea of how to solve the problem. In the mean time, I may look about trying the above solutions.
Kevin
    Hi Nivenus :)
    I'm not a tech expert by any stretch of the imagination, so for more detailed help you might have to wait until someone more tech-savvy arrives on the thread. But I do have a shared experience that may or may not be relevant.
    A couple of months ago I had massive issues with Explorer crashing in Win 11 and then continually failing to restart, so that all the monitor could do was flash about twice a second leaving no time for me to do anything at all except hit the restart button on the PC. It was so severe that I had to ask for help from the PF team and from the PC manufacturer to try and sort it out. (My machine is only 9 months old)
    In the end I had to uninstall a piece of third party software that allowed me to place the Start bar where I like it at the top of the screen (Win 11 is totally inflexible and places it at the bottom of the screen whether you like it or not), and prevent the optional Win 11 updates. That means switching off the "Get the latest updates as soon as they are available" option in the settings under "Updates". These optional updates are a kind of beta release (as I understand it) and can sometimes be a bit buggy.
    Since doing those two things I haven't had any problems with Explorer at all.
    Nivenus
    CC3+ doesn't install anything that even integrates with explorer, so I am really struggling with coming up with any case where this would be caused by CC3+. Certain 3rd party programs that changes explorer behavior, like Sue mentioned, can certainly cause this behavior, but there are no components installed by CC3+ that explorer would refer to, so when CC3+ isn't running, it is like it doesn't even exist as far as explorer is concerned.
    The only "integration" that exists is the file type mapping that causes explorer to recognize the .fcw file type, displaying the right icon, and allowing CC3+ to start when you double click the file. But that is core explorer functionality, and all CC3+ really does is tell it where the executable is by giving it a text string, it isn't an actual add-on to explorer itself, and CC3+ does it exactly the same way as any other program.
    When it comes to Windows 11 and Lenovo Legion Pro, I have that combination myself (A Lenovo Legion Pro 5i [2023]), and CC3+ works perfectly fine on it.
    When you did your clean reinstalls of Windows, did you install anything else before CC3+, like a custom virus checker or something? (I have to admit, that 6 month trial of whatever Lenovo shipped with my machine went out the window almost immediately, I prefer Microsofts own, and I certainly don't want something I have to start paying on in a few months). Most antivirus software works absolutely fine with CC3+, but I am just trying to find some commonalities that could be a probable cause.
    roflo1Nivenus
  • Interesting. Yeah that sounds super super similar, though the trigger appears to be slightly different. I do suspect a Windows update may be related since a new one was released not that long ago and it might not have installed on my system until a couple days ago. I did try rolling back to a previous version from the boot menu but it then just installed the new update right on top of that anyway so I don't know for sure if it had an effect or not.
    Yeah it's really bizarre. I honestly don't know why it would be having a problem with Explorer especially since it seemed to work fine until just a couple days ago but I do suspect somehow the most recent Windows update is involved, as described above.
    So I went ahead and gave it another try to document when exactly it begins to glitch up and cause the recurrent Explorer crash/restart/crash problem. During installation, I selected the following options:
    I wasn't able to catch a screen of the glitch because of its nature interrupting the "Print Screen" function but it began to occur as the installation said it was "removing backup files." No idea what that refers to but it could possibly be related.
    I then went ahead and did an uninstall to remove the problem and watched carefully for when it stopped. It appears it stopped when it got to the stage of the installation that said "removing shortcuts." By the time it got to the next section below, I could take a screenshot again.
    Thanks for the quick replies all. I was not expecting support this quickly since it seems as though CC3+ is a pretty niche product! But I appreciate it.
    You're welcome :)
    We're usually around the place quite a lot.
    Was everything ok once you finished installing it?
    EDIT: Stupid question. I wasn't really all that awake when I asked it. I take it you haven't yet managed to install CC3+?
    Nivenus
    Did you try rebooting your computer after the installation to see if the issue continued after that? I obviously have no idea why this is happening to you, but if something is being done during installation for some reason causes explorer to start crashing, a reboot will at the very least restart every part of Windows.
    You should also contact customer support through your registered user pages. Maybe they'll be able to work out something with you, like trying an alternate build of the installer.
    Nivenus
  • Have you tried doing a disk check/repair? This sounds like a bad directory structure or bad location on the drive or SSD that keeps being written to.
    Nivenus
  • Nope. Haven't been able to install it yet without the issue.
    Restarting was the first thing I tried, before anything else, since I was hoping that would fix it. But nope.
    The idea to contact customer support is a good one though. Thanks.
    I did look into a System File Check, but it didn't pick up anything. Haven't tried a disk check though so I'll give that a look.
    Thanks for the continued feedback folks.
  • 1 month later
  • I had the same problem when I replaced my OS drive and reinstalled the program. I also had to uninstall CC3+ to make it stop. I did fix it though by first installing CC3 pro. When I went through the install process I discovered that I needed to first install dotnet-sdk 7.0 or 6.0, also Visual C++ Runtime v12 Framework package, which was not installed when I installed CC3+ for whatever reason. I also encountered the same issue when I installed The Tome of Ultimate Mapping for CC3+ and it placed the pdf file on my machine's public desktop. I had to reboot and use the repair my computer features from the Windows install disk. Went to the command prompt and manually deleted the file from the Public desktop folder after copying it to a folder on another drive. After deleting the file, which was only a pdf file the machine rebooted into Windows without any problems and the constant blinking stopped.
    I just can't figure out how putting a pdf file into any folder would cause that kind of problem. Just to test it I put a few other pdf files I have into my public desktop folder and nothing happened at all. When I, again ran the setup program to install the ToUM for CC3+ the problem reoccurred. I have absolutely no explanation for why this happened, and it only happens with the Profantasy software. It never happened to me before. I have had this computer for a number of years and have reinstalled the programs a few times when I replaced my OS drive. This is the first time this has ever happened to me.
    Out of curiosity, do you have a 3rd party pdf reader installed? I am trying to think up scenarios why this would happen, and the only reason I can think of for a pdf file to crash explorer if is the PDF viewer on the system is trying to create a thumbnail for the file, failing to do so, and have poor error handling so it crashes taking explorer down with it instead of handling the error gracefully. This would then repeat as it would try again immediately when explorer opens again.
    Now, this is just pure guesswork at this point, but since it seems to be a very rare problem, it is worth checking out if you have anything on the computer that might be different from the regular user that could interact.
  • I do have a 3rd party PDF reader installed. It is not the default reader, though. I have Adobe Acrobat Reader set as the default. You might be right as far as the Tome is concerned, though I never considered that possibility.
    Theoretically, it could be the thumbnail provider even if it isn't the default reader. Could you tell me which reader that might be, and ideally the exact version number of it so I can just try and see if I can reproduce the problem? Not sure it will lead to anything, but it's worth giving a test.
    I have Samba pdf reader and I don't have this problem. No Adobe though unless I count Open Office.
  • Sure, I use Soda Desktop pro to create and edit pdf files, Corel Fusion to combine multiple documents, pdf WinZip express because it came with the suite I got from Winzip, and PDF 24 to print documents in pdf format. I know that is a lot of them, but the work I do requires me to do a number of things with PDF files that one stand-alone editor doesn't do.
    Nice collection. It does make testing a bit harder, but at least I have something to try.
    I'll see if I can find anything. Maybe there is an overlap with what @Nivenus uses. (Or maybe I am barking up the wrong tree here, but figuring out weird problems can be difficult, so anything can be worth trying)
  • I did forget to give you the version numbers, so here they are:
    Soda desktop Pro ver 14.0.365.21319
    Corel PDF Fusion ver 1.10 build 2011/12/13:21:00:00
    Winzip PDF Express ver 3.0 (15640 - 64-bit
    PDF 24 is the latest version to download on their website.
