Lighting Question
EdE
🖼️ 14 images Traveler
Can anyone tell me why the wall section behind the light source that I have circled (lower RHS) is in shadow instead of lighting up like the other "lighted" wall sections. Could it be overlapping Glow effects from the inner and outer walls? I have two Walls sheets, each with it's own effects. The lighting is on the Wall sheet which contains the outer walls. The Wall Inner Sheet renders before the Wall sheet. Just a bit confused.
I can't help with this. But I would suggest posting the fcw so someone can look at it.
Thanks JimP. I'm sure it's something really simple that I am missing.
Does it look like this inside CC3+, or only on the exported image.
If the latter, try this
I also noticed that there doesn't seem to be a light source located in the torch in question, while the torch north for it, as well as the one on the south wall both have 2 light sources in each. (Use Dungeon - Lights -> Show light symbols to visually see their location)
Thank you, I'll check that. I have the light symbols turned off so I missed that. I added one set of lighted symbols (torches) and decided to change the torches for lanterns. Apparently the Delete removes the symbol but not the light source "X". I'll see if that makes a difference.
Thank you Monsen, that did work
