Lighting Question
edited July 2022 in Show and Tell
Can anyone tell me why the wall section behind the light source that I have circled (lower RHS) is in shadow instead of lighting up like the other "lighted" wall sections. Could it be overlapping Glow effects from the inner and outer walls? I have two Walls sheets, each with it's own effects. The lighting is on the Wall sheet which contains the outer walls. The Wall Inner Sheet renders before the Wall sheet. Just a bit confused.
