WIP A Murder Scene
EdE
🖼️ 14 images Traveler
I am trying to simulate sunlight shining through a window, specifically the window on the left wall and the one on the front wall to the right. I changed the color on the Wall Shadow, Directional effect to a bright yellow and used the Global Sun setting so it matches the shadows cast by the wall. I added a stronger shadow to the sack just below the left window and the cauldron to the right of the front window. Does it work or am I just messing up the map? Any thoughts are appreciated.
No that's a good idea. Have you thought of making it a more pale yellow? It will show up a little better.
I can remember doing something similar myself a couple of times.
Good suggestion, my first attempt was a less vibrant yellow and I couldn't see it at all. I agree it could be a bit less intense.
Making the map darker overall gives you more room to highlight areas; but that's more if you don't want just a subtle touch and really want to play with the light
Thank you for the suggestion, I'll play with that a bit. It might help bring out the sunlight.
