Find Symbol Catalog File
How do I tell which FSC file a particular symbol definition in my map is located? I made some custom symbols and I can't remember which file they are saved in.
Thanks,
Daniel
Thanks,
Daniel
For a great primer on LIST, check out Monsen's excellent first Command of the Week forum post.
I found symbol manager, which gave a lot of great options, but not this.
Thanks
The only way to find it to use some guesswork. If you use the List button inside the symbol manager, you can see the list of the individual elements of the symbol itself, which will let you see the file name of the image, assuming it is a raster symbol. From the path of the image file, you should have a reasonable way of finding the symbol catalog too.
If it was a vector symbol it gets way more difficult though, because these don't contain images with filenames, so there is no way to trace them.
Thanks for the hand. Again. Cheers!
I remember I found it by looking at a PDF Look Up Sheet that had several pages and the last was labeled Modern.
When I used the symbol in a particular map, it loads with that map, but all the other available ones of course do not.
I used the List command to find the symbol name and it was M-Deciduous Forest CA85 which made me look in the modern category and then I thought, aha, it must be in CA85 which is the WW2 map annual, but I didn't see it there. I keep thinking it would be in the SS2 or SS3 sets, but no joy there apparently.
Hopefully there is someone with better searching-fu than I have or a better memory and help me out. This has been 3 hours of my day trying to refind this stupid FSC. ARGHHH.
And I just tried using the Search file in text which appears to have crashed the program.
For anyone who is interested, I took a screenshot of the contents.
