What is the big green shapes?
Hi Team,
Occasionally I see some pretty weird things when I save a map to JPG, etc.
https://drive.google.com/file/d/0B_6BXlzLTlj8dWFMSlN2aThZMk0/view?usp=sharing
This is a good example... any idea what the huge green shapes in the middle are? I certainly haven't knowingly put them in.
daplunk
daplunk
3000*3000 does not display what ever it is but the resolution is too low for a battlemap.
Here's a copy of the file.
https://drive.google.com/file/d/0B_6BXlzLTlj8aFh2alRkQkhTLUE/view?usp=drivesdk
I'll have a look at that in a minute
I can't even open it. Your file is causing CC3+ to crash the moment I click on it, and that's before I hit the open button!
It should help to increase the max number of pixels per pass (I couldn't replicate your problem until I reduced my value), but be careful with this value, set it too high and it can cause crashes when rendering. I recommend backing up the file before editing it so it is easy to fix should that happen or you do another mistake. See Sue's post here for details.
Note that deleting/modifying your lights should also fix this, but I assume you wish to keep them.
Monson, given the colour I suspected it had something to do with the lights. I'll try this out tonight.
I don't think either of those would cause problems.
I was able to do a list on the green lines.
Sheet Floors, Layer Secret. Screenshot attached. The green lines are all connected. The lines are the only green I see. I have attached the fcw file.
Time to start writing the content for this death trap.
