Symbols blurry/distorted after map export
                    Hi, I used Dungeon Designer 3 to create a dungeon map. When I was finished, it looked pretty good and everything was clear even when I zoomed in. However, when I tried to export it as a png and viewed it, after I zoomed in the symbols were all pixelated and blurry. I need them to be clear because I'm going to use the map in fantasy grounds and will have to be zoomed in to move miniatures around. Is there a recommended (a la carte) way to make the maps very clear even at a zoomed in level? Please explain in great detail, I'm a little new to the software.
Note: Remember that "pixels per inch" is meaningless for image exports like PNG or JPG (not just for CC3 but any time you export or resize an image on a computer). Pixels (or dots) per inch is only useful for paper output and, even then, CC3 can do the proper calculations based on map units.
Cheers,
