Wall-cutting problems
... in DD3+. I recently bought the SS4 "Dungeons of Schley" and started a try to recreate the Curse of Strahd "Blue Water Inn" using this style. So I did the walls using the "default wall" tool", which worked okay. But then I tried to insert the Entrance doors, and miserably failed. First, I tried to just smack on the door ... I chose it from the icons, I hovered it over the section of wall I wanted to put it, the icon aligned itself correctly, and then I clicked to actually put it down. What happened was the door being blotted down in a 90°-angle to the wall it has previously been aligned to, and no cut in the wall being there (see picture below). Then, neither the "break" tool nor the "wall cutter" tool seem to be effective.
What am I missing?
