Is there a way to select ALL copies of the same symbol?
I've created a large forest in CD3 using the variations of CD3B Tree and CD3B Bush and have noticed that by default these symbols are loaded onto the SYMBOLS sheet and the VEGETATION layer.
I've found that I could easily move all the trees and bushes to the VEGETATION sheet, but I'd ideally like to have all the trees on a TREES sheet and the bushes on the VEGETATION sheet. That way I can apply different shadow lengths to them and also ensure that the bushes drawn before the trees preventing a small bush overlapping a large tree.
I can obviously do this by selecting each tree manually one at a time, but based on the number of individual trees I've already put down, this will take forever.
Is there a way that I can select a tree (e.g. `CD3B Tree 1`), and then have CD3 select all other copies of the same version of that tree that are on the map?
If not, can it be done by a macro? and if so, how?
1) Copy all the symbols from your VEGETATION layer to a new map (using ctrl-c & ctrl-v with an origin of 0,0).
2) Name the new map "trees.fcw"
3) Save the new map again, this time call it "bushes.fcw"
4) Using the symbol manager to delete all the trees from bushes.fcw, and all the bushes from trees.fcw.
5) Set up the symbols onto correctly named sheets within the two new maps.
6) Delete all bushes and trees from the original map.
7) Use ctrl-c / ctrl-v to copy the symbols back from "bushes.fcw" & "trees.fcw" (they'll paste into the correct sheets, creating a new sheet on the top on the stack if no sheet with the correct name exists).
Cheers,
I hope 01i saw the idea before restarting the map.
http://forum.profantasy.com/comments.php?DiscussionID=4257
