Node editing as Jim explains is a good option. Another good option is to use combine path to merge the walls back into one entity again. Combine path is explained in this article (you'll want to skip steps 7 and 8, as those are for turning it into a polygon, which you don't need)
Door, or window...
I freeze all but walls. If the wall is straight and level or vertical, i click on Ortho bottom right.
Then I use the Node Edit tool on the left to select and drag the wall so it closes the opening.
It may take some care to accomplish.
