Looking for Symbols of D&D style Dice
Hello everyone
I am looking for a symbol of a 20 sided to put on a heraldic device for a school gaming group to have a logo of sorts. Has any one ever made one ?
The device so far is quartered white and green with green eagles in the white quarters. I wanted a white die 20 for the upper green quarter and some thing else (kind of gaming related) for the lower green quarter. Their school colors are green and white and the mascot is a seahawk.
Any help and other ideas will be very appreciated.
Darren
I looked and could not find any quickly but if you find a jpg or png image you could follow @EukalyptusNow tutorial (link below) and create your own. It doesn't really take that long to do.
https://forum.profantasy.com/discussion/12954/how-to-create-decorative-symbols-by-tracing
I also found this blank one you can use to create your own. From a free download site.
Wow That was easy ! thank you for pointing me to the step by step !
thank you
Darren
Your welcome. Glad I could help.
this is how it looks so far
I am having trouble trying to connect the lines that make up the d20. Is there a way to do this and make the white lines of the d20 a single entity or just make the lines connect better ?
You can't connect more than two lines at each node, or point of the dice. Instead, try drawing the outline as a hexagon and add the triangle in the middle, then draw the other details as single lines, but move them behind the hexagon and triangle. That should hide the untidy bits.
Also, instead of using lines with outlines, make two sets of lines, white lines on top of black lines. Make the black lines slightly wider than the white ones, and they will do the job of an outline without getting in the way.
Thanks guys ! 😎
