 - Loopysue
 - 9,987
 - Member, ProFantasy
 - 9,864
 - June 29, 1966
 - Dorset, England, UK
 - Real Name
 - Sue Daniel (aka 'Mouse')
 - 27
[WIP] - Sakherma Ruins
Whichever fill you use for the dunes, I recommend making the bevel wide enough that the dunes have a ridge at the top instead of a bump. If you add an Edge Fade, Inner to the dunes as well, the bottom of the slope doesn't hit the ground so sharply. Adding an EFI also blends the fill of the dunes with the background a lot better.
These are the sheet effects settings for the above example:
You may or may not want the shadow. That's up to you. But if you do want it I recommend using an ordinary "Wall Shadow" and not the usual directional one. It plays better with the other effects.
Deep sea problem
How about this?
I added a Colorize to the background and then drew the shallow water under the land with the "Sea" drawing tool.
fill style locations
Hi Brian :)
There's no catalogue of fills, as such, but they are usually named in a fairly standard way. For example if you go to the C:\ProgramData\Profantasy\CC3Plus\Bitmaps\Tiles folder and put "Farmland" in the File Explorer search bar, you will discover all the fills called Farmland from all the styles you have installed.
Can you link to the video where you saw this fill being used? Many of us can identify styles from the fills and may be able to help you locate it that way.
There are lots of free third party assets available. This is a useful thread to explore:
Live Mapping: Satellite Streets
Hi Everyone! :D
In this week's Live Mapping session Ralf will be trying out the latest Cartographer's Annual issue (November 2024) with the Satellite Streets style.
Come along and join us live on Youtube to join in the chat here:
https://www.youtube.com/watch?v=uJ4g_hhSgGU
Or you can watch it here later if you wish.
Strange Behavior with Marine Dungeons
