- Loopysue
- 10,020
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
WIP - Tomb of Shadows
Free symbol pack - Tentacles
The reason that Resource thread is closed is to stop it becoming unweildy to look for assets between all the comments that might otherwise appear between the different packs. When I make the next pack there will be a new comment on that closed thread where you can download the assets and a new 'more info' thread for that new pack.
Free Assets by Sue Daniel
Tentacles
Tentacles is a small set of 9 dungeon-scale tentacles with built-in water splashes. They are intended for use with water features such as lakes, rivers, sewers and ponds.Download ZIP file File size: 30MB
These symbols can be accessed via the Skirmish Symbols button|DD2SKIRMISH| from DD3, Creepy Crypts, Forest Trail and Winter Trail templates, and from the Vehicles button|CATICON5| in SS3a. Alternatively, if you are navigating to find the catalogue file from any other template it can be found here: @ Symbols\User\Sue\Tentacles.FSC
This thread contains the download files and folders for the smaller sets of symbols and fills I have created over time.
Each set comes in the form of a zip file. Unzip it into your CC3+ data directory (C:\ProgramData\ProFantasy\CC3Plus if you installed it to the default location).
Note that it is the content of the zip files that goes into your data folder, make sure your unzip software does not create any extra directories based on the name of the archive. If you end up with unintended subdirectories, the resources will not work properly.
If you run into problems installing any of these sets, each comment below contains a link to a dedicated More Info thread where you can ask for help if you need to.
Any specific instructions about how to access a set once you have unzipped the folder are given with each download link.
All the following asset packs can be used in maps for the Community Atlas providing you install them as directed.
