9,977
Member, ProFantasy
9,859
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Free Assets by Sue Daniel
    Tentacles
    Tentacles is a small set of 9 dungeon-scale tentacles with built-in water splashes. They are intended for use with water features such as lakes, rivers, sewers and ponds.
    Download ZIP file   File size: 30MB
    These symbols can be accessed via the Skirmish Symbols button|DD2SKIRMISH| from DD3, Creepy Crypts, Forest Trail and Winter Trail templates, and from the Vehicles button|CATICON5| in SS3a.  Alternatively, if you are navigating to find the catalogue file from any other template it can be found here: @ ​­Symbols\User\Sue\Tentacles.FSC
    More Info
    hsv216TheschabiEukalyptusNowWyvernRaikokilma.ard.venomcyrionMathieu GansJimPFey
    This thread contains the download files and folders for the smaller sets of symbols and fills I have created over time.
    Each set comes in the form of a zip file. Unzip it into your CC3+ data directory (C:\ProgramData\ProFantasy\CC3Plus if you installed it to the default location).
    Note that it is the content of the zip files that goes into your data folder, make sure your unzip software does not create any extra directories based on the name of the archive. If you end up with unintended subdirectories, the resources will not work properly.
    If you run into problems installing any of these sets, each comment below contains a link to a dedicated More Info thread where you can ask for help if you need to.
    Any specific instructions about how to access a set once you have unzipped the folder are given with each download link.
    All the following asset packs can be used in maps for the Community Atlas providing you install them as directed.
    hsv216JulianDracosEukalyptusNowWyvernkilma.ard.venomAleDMathieu GansFey
  • Free symbol pack - Tentacles
    I created this pack of tentacle symbols for use in the Sewer Encounters Live Mapping session by Remy Monsen, in which he explains as part of the show how to create your own new symbols from graphics from outside the Profantasy collection and integrate them into the CC3 system.
    The pack contains 9 dungeon scale symbols and can be downloaded here.
    Here is an example of the tentacles used in a Winter Trail map.
    MonsenJulianDracosjmabbotthsv216TheschabiEukalyptusNowWyvernkilma.ard.venomJimPGeorgeand 1 other.
  • Winter Trail Project
    Well, I finished the more simple map as one of the example maps, and I think it shows the style more clearly. One of the other examples is a conversion of Ranger's Hill from Forest Trail part 2. It should be reasonably easy to convert Forest Trail maps to Winter Trail maps.
    Winter Trail is due out as the March issue this year.
    Both of my example maps can be viewed at much higher resolution in my New Style Example Maps gallery.
    JimPWyvernWeathermanSwedenkilma.ard.venom
    There's something prowling around at the stones, so better not go out today.
    MonsenJimP[Deleted User]WyvernGlitchWeathermanSweden
