- Loopysue
- 9,975
- Member, ProFantasy
- 9,855
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Free symbol pack - Dungeon scale connecting hedges
I made these connecting symbols 4 years ago back in 2019. It was the first connecting symbol I ever made, so it isn't drawn to the same standard I prefer to use today. However, it still works well enough if all you want is a really fast maze map. The connecting hedge doesn't officially match any particular dungeon style, but it works reasonably well in a DD3 dungeon map as shown below.
The pack contains one set of connecting hedge symbols and a symbol catalog with two options. The first pair of symbols in the catalog are the original imperial hedge that is 3 feet wide with it's associated 3ft diameter end bushes. The second pair of symbols is a metric conversion of the same, where the hedge is 75cm wide. If you have problems with hedges looking broken or sticking out too far at the corners the most likely cause is that you are using the metric hedges in an imperial map, or the imperial hedges in a metric map.
The connecting hedge pack can be downloaded here
Here is an example of the hedge used to make a maze map in DD3.
Maze pattern source: mazegenerator.net (licence required for commercial use)
Useful tip: When you have finished drawing your maze, use the round hedges to cover any visible joins at the corners.
Hedge Tool
I can't say if they would work with any style in particular since they were created a couple of years before I started making any dungeon scale annuals, but the maze map was done using a DD3 template with DD3 fills and assets.
I'm looking at a couple of weeks before I can really sort this out, but its on the 'To Do' list.
I should warn you that where I wasn't really aiming to make them perfect at the time the quality isn't perfect. They do look a bit false close up. This was before I got really high tech with vegetation - pre Blender trees. But if all you want is a quick maze they might do. I got a few of the set working to get a better screen shot. The rest is still red crosses at the moment.
Imperial only as well.
Hedge Tool
I've located the original work files for this set of hedges from about 3-4 years ago. Unfortunately the symbols themselves need to be regenerated and the source files look a bit of a mess. But is this the sort of thing you were looking for? If it is then I can do a free symbol pack here on the forum, but it may have to wait for more pressing projects to be completed first. That might be several weeks.
a magic? map
Free Assets by Sue Daniel
Tentacles
Tentacles is a small set of 9 dungeon-scale tentacles with built-in water splashes. They are intended for use with water features such as lakes, rivers, sewers and ponds.Download ZIP file File size: 30MB
These symbols can be accessed via the Skirmish Symbols button|DD2SKIRMISH| from DD3, Creepy Crypts, Forest Trail and Winter Trail templates, and from the Vehicles button|CATICON5| in SS3a. Alternatively, if you are navigating to find the catalogue file from any other template it can be found here: @ Symbols\User\Sue\Tentacles.FSC
