- Loopysue
- 9,971
- Member, ProFantasy
- 9,853
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
WIP - first crack at a larger scale city
This file won't save properly with the upper land mass
No, there's no Discord that I know of.
The best technical help is more available on the forum right here, where it's also possible to upload many more file types and much larger images than on other platforms.
There is an FB Group, but you will have to answer the questionnaire before you are accepted.
Remy identified the TERRAIN WASTE sheet, and in particular that topmost polygon of it. I used SIMPLIFY on that one poly with the distance set to zero, so that it only removed nodes that are exactly right on top of one another. I then had to put the top left corner of that poly back in.
There were also a couple of stray symbols way off the map bottom left. I just deleted those.
You can probably do this yourself anyway, but in case my success was a fluke here is the FCW
Live Mapping: Using FT3+ continents in CC3+
Hi everyone! :D
Following from some ideas in last week's live mapping session, Ralf will be looking at using Fractal Terrains-generated material in CC3+ overland styles in tomorrow's live mapping session.
Come along and join in the chat here:
https://www.youtube.com/watch?v=iqW-kQ7cC60
Or watch it here if you prefer, though there's no live chat on the forum.
Recommendations Requested: Must-Have Annuals?
I have a wall of links here you can use to see what's in the annuals.
It's in need of an update right now, but you already have last year's annual.
