- Loopysue
- 9,968
- Member, ProFantasy
- 9,853
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
A Command that Changes the Number of Passes when Rendering.
How do I remove lines
Inn/Tavern battlemap (WIP)
That's a really good map elezriata - and "Hi" from Sue Daniel ;)
Have you heard about the Vintyri Collections? These are huge collections of free third party art assets that might help with things like more variation of rugs and furniture.
The links for all the assets can be found here:
Where the Vintyri collections in particular are concerned please read the installation instructions really carefully.
Live Mapping: Sheets and Sheet Effects (Part I & Part 2)
WIP: Community Atlas Competition, The Lost temple of Ankun-za
If you right click the polygon tool on the right you will find "Shaded Polygon (Angle by edge)"
Use that tool, and click the edge you want to align the fill with.
This will also cause the polygon to be shaded like a pitched roof. You can get rid of the shading but keep the fill alignment by typing EDITSHADING and hitting enter. Check the command line. It will ask you for the entity to edit. Click your polygon and a dialog will pop up. Don't be put off by all the controls. The only thing you need to do there is check the little box called "Shade Only Copy", and OK.
Once you have done that you should be ok.
