- Loopysue
- 9,983
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
CC4?
Overland Template Suggestions - Continent Scale
The wall of links that Jim mentioned above is here:
Wall Mural Symbol
breaking up repetition with bitmap scale variations
Yes, I remember there being something myself but I can't find it now either. We must both be using the same 'wrong' search words.
But never mind - I can possibly help you here.
Make a new sheet immediately above the one with the repetition issue (under it in the sheet listing because the sheet listing is upside down to most people's way of thinking).
Either:
- use one of the semi transparent fills (denoted by having a 'T' in the fill name in DD3) in patches on that sheet, or
- add an Edge Fade Inner sheet effect to the new sheet, and then draw patches of similar textures on that. When you refresh the drawing the EFI will blend the edges into the old sheet.
It's more effective to use similar textures rather than the same one. For example if you have several shades of grass use one of the other shades of grass to patch the original grass.
It can take a little practice to get the second method to work correctly, but I've found it more effective than the first one.
EDIT: It is also worth remembering that repetition becomes far less obvious when there are more objects in the map, so if you are staring at just the background with nothing else at the beginning of a map you will inevitably see the pattern. It might be worth finishing the map before you decide to go through the process of patching.
converting polys fractal to smooth?
Yes, that's very true.
@HelenAA - Joe's recommendation will also prevent the 'fly away' artefacts you can sometimes get when smooth nodes are more or less on top of one another, for example when converting a more extreme fractal line or polygon.
