Jeff B
Jeff B
- Jeff B
- 5,900
- Member, Betatester
- 1,239
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
[WIP] Kalimdor
Use both use the spectrum trees for the snowy areas and the darkland trees for the other areas and throw in some autumn spectrum where you think they would work. In my Endoria map I'm currently using symbols from 4 different styles even though the overall map is spectrum overland. Also using fills from multiple styles so consider using the snow fills from spectrum where you need them.
Her is a sample using spectrum, darklands and the HW together. And yes the terrain is the rusty metal from darklands. Thought it fit well for what I was trying to do for the area
WIP - My New World - Myrrhina
I would try changing your political boundaries to different colors for each area. You can have two or more areas with the same color boundary but just not next to each other. That would separate the boundaries better and make it easier to see where the boundaries are. I would also use polygons for the area with a filled color and a sheet effect to just show the boundary edges. after you use the smooth poly tool to make the boundary. then use the smooth to straight command to turn the area into a straight poly then you can use the trace command to trace the border of the neighboring region. Once your all done you can leave them as straight or change them back to smooth polys by using the straight to smooth command.
Just an idea for you to think about.
sample below - not all done but this is what I'm currently working on
Cc3+ text on non cc3+ map versus photoshop?
Need Style Suggestion for Azeroth (World of Warcarft) Map
Endoria
Well I decided to post in this thread instead of creating a new one. I have finished the eastern portion of the world. I know this is a large map with way too much detail but that is what the person I'm doing this for wanted and it's too late to change now. He plans on printing a large format print with detail to hang in his game room. He created this world over 40 years ago and had very little of the world explored so except for the area he had already mapped out I'm able to have free rein over how it looks.
I still need to update political regions (turned off on this posting) and label the rivers but most everything else is completed.
Once the map is completed I add sea contours and a few islands along with scale and compass.
larger image in gallery
comments and suggestions welcome as always
