Jeff B
Jeff B
Jeff B
5,899
Member, Betatester
1,238
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • [WIP] Atlas Contest : Ingensteds Village, Seal Island, Alarius
    Ok started working on lighting for the map. Still have more stuff to do but here is the current version I'm working on.
    Dark Version
    Lighter Version
    Royal ScribeQuentenLoopysueGlitchRickoShessarDak
    Still a WIP. Need to add some more details and adjust the fonts but thought I would post to get some ideas of what may need to be changed / adjusted.
    Ingensteds is a remote village on Seal island in Alarius. The area is covered in snow most of the year and the sea ice rarely recedes from the land. The people that live in the village like or even relish the isolation. The community works together to collect food and collect resources they need to survive.
    LoopysueGlitchRoyal ScribeQuentenRickoC.C. CharronShessarDak
  • Print Issue
    Sue,
    The edge effect works fine if you change the setting to use map units instead of Percent of View width and move it below the glow effect. suspect the effect is grabbing the purple glow. As during some playing around I had the entire CC3+ display window purple with the effect on.
    PNW,
    You should be using the map units option for your effects it will give you less problems than Percent of view width.
    JimPPNW AnglerLoopysue
  • Happy Holidays !!
    Happy Holidays to everyone. Be safe and enjoy your time with family and friends.
    JimPLoopysueMonsenRickoRalfWyvernroflo1WeathermanSwedenadelia hernandezpablo gonzalez
  • Campaign Cosmographer Insert template
    Ok there is something wrong with your file. I was able to insert the png. But I would start over from scratch. Unzip the file below and keep the ,FCW file in the same place as the .png and you should be able to see the drawing. I have placed it on the trace sheet and given it a 50% transparency.
    Alirode
