Jeff B
Jeff B
Jeff B
5,899
Member, Betatester
1,238
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • Forest Trail project - part 2
    You can edit the grass terrain drawtools to put the various grass textures on different sheets. Doing so will keep the new sheet in each map you create as you are editing the tool itself so it's not tied to the map.
  • My First Floorplan: Cybperpunk Club
    Yep looks good now. Glad I could help. The lights behind the bar don’t look so strange now.
    You have a purple/pink light in the upper left corner that appears to be set at 180 and facing the wall. It has a very hard line caused but the setting but the same corner in the lower left has a 360 light. I would change that upper light to 360 to remove the long harsh line it is creating unless that was the intent.
    Try changing the light at 33,187 from 90 to 360.
    jslayton
    Ok use the following setting to render the image.
    Enter this command:
    EXPORTSETMPPP - enter key
    80000000 -enter key
    then do your save as and select the image type you want and adjust options as below if needed. You can change the Width and height if you want but don't go too far above 35% antialias
    Here is how I set up the options in the save dialog before saving the jpg / png
    Also if you want editing lights to be easier create a sheet for each color and make sure you put each color light on the correct sheet. That way if you want to edit the pink lights hide all the other color lights and your light list will be easier to deal with.
    roflo1
    have you set EXPORTSETMPPP to at least 40000000 ? this may help when exporting the image.
  • [WIP] Project-A
    @jslayton
    CC3+ Closed - double click on .FCW file 16 seconds to open. (Effects are on when file opens)
    Click on toggle show light symbol buttons (Thank you Remy for that great tutorial) 15 seconds
    Toggle global sun off = 1 second
    toggle global sun back on = 15 seconds
    toggling effects on is also about 15 seconds
    The above testes were for the default size on screen if I zoom in to fill the window with the image it takes 18 seconds to redraw.
    rendering effects always triggers laptop fan to turn on
    rendering to jpg
    setting 5000 5000 300 ai 35% (exportsetmppp = 40000000) = 6 minutes 40 seconds it takes about a minute to get to the LIGHTS GLOBAL Sheet. It look like it is taking 5 minutes for the lights to render after the LIGHTS Global appears and then the message about writing the file to a jpg appears.
    setting 5000 5000 300 ai 35% (exportsetmppp = 80000000) = 7 minutes and 20 seconds
    Hope this helps
    EukalyptusNow
