- Wyvern
- 3,240
- Member
- 5,523
- 24
Live Mapping: Monthly Symbols Dungeon
Wilderland Campaign
[WIP] Azeroth Classic
The CSUAC trees are part of the free third-party resources you can download and install for use with CC3+. The process is not straightforward, however. If you want to try, you can find the links on this Forum information topic.
Forest Trail project - part 1
This used to happen with new sheets you'd created in any map. If you didn't put anything on the sheet, it would be deleted the next time you reopened the map. That was changed in an update a long while back, and while it does solve the problem that if you don't use it immediately, you'll lose it, it does mean most maps now end up with far too many sheets in, because nobody's ever going to remember which sheets haven't been used in a given map. Plus there's always the danger you'll accidentally delete some critical sheet by mistake that has something on you'd forgotten about if you try to do a cleanup manually.
It would be excellent to have the same possibility to remove excess Sheets at the end of a map, just as you can with Layers, currently. Not sure how practical that would be from a programming perspective though.
August Mapping Competition - The Results
