- Wyvern
- 3,238
- Member
- 5,516
- 24
CA style development - "Darklands City" (issues for September and December 2021)
Are there steampunk resources for CC3+?
I think the problem we're having in helping you is we don't really know what YOU think constitutes Steampunk, or what it is you're trying to map, so just saying you want Steampunk assets without saying what they're for, is a little like asking us to give you a piece of string to accomplish a task you can't define. Now you're saying you found some Steampunk packs elsewhere but they weren't what you wanted (which rather goes against your prior comment that anything under the Steampunk label would do). Maybe if you could say what assets you DO want and what it is you want to map, instead of what you don't, we might be able to help more. It's clear you know what you're looking for, but we don't.
Certainly there is no ProFantasy pack that carries the specific "Steampunk" label, if that's all you were hoping for, although that doesn't mean there aren't assets you could use in that genre in many other packs, as we've tried to indicate in the notes above.
We've had several discussions on the Forum here (and these have happened elsewhere too) over recent years as to exactly what this or that RPG/fiction genre term actually means - including Steampunk, Grimdark and Cyberpunk. The problem with all these is they mean different things to different people, which can be tied sometimes to what they are taken to mean by specific RPG systems. This makes it hard to say what assets a given person might consider satisfactory, aside from this also depending on what scale of mapping is intended - whole country/region (what we often call overland in CC3+ discussions), entire settlement (CC3+ "Cities"), or individual buildings ("Dungeons"), for example - and what the map is going to be used for (an individual building map might be used as a tabletop battlemap for miniature figures to move and act across, say).
Some kind of loosely 19th-century or "Victorian" mapping options might be easier to find, though there isn't a standard set of options even looking there, as most 19th century real-world styles started out in the previous century, and their 19th-century developments carried through into the first third or half of the 20th in different places. In terms of CC3+ assets, there are overland styles such as the late-18th century Ferraris Style from the February 2020 Annual, which general look of maps was still being used in places into the early 20th century, and some elements still feature in maps today. It works well for local areas/small regions and settlements. The August 2009 Annual covered Napoleonic battle maps, again suitable for relatively smaller areas, and a style used from the late 18th through to the early 20th centuries.
The Early Modern Cities style in the 2007 September Annual will fit with some later 19th-century city maps. For 18th-early 19th century sailing ships, try the March 2009 Annual, updated with additions in April this year. Although strip maps (May 2009 Annual) were a 17th-century development that was a method still being used well into the mid-late 19th, showing details just along and near a specific roadway.
These are only a few examples that come readily to my mind. I'd recommend taking a look at this Forum topic, which shows thumbnails from every Annual issue, and gives a simple guide to the general style presented in each issue, with a link to the PF website where you can find more information, including examples of the style in use.
@JulianDracos makes a good point regarding the vagueness of the genre, in common with what I've noted here. RPGs such as Castle Falkenstein and Space 1889, and also Cthulhu By Gaslight, which to me would fall into the loose Steampunk genre, tended to prefer clear, black-and-white line-drawing styles for their maps, sometimes with straightforward simple colours used to highlight particular things, which also seems comparable to how many 19th century maps come across to me.
Wishlist for CC4
@Glitch - Something else you might try is having a second window with another program (such as Windows Explorer) on full screen mode, so it hides the CC3+ window completely. This helps stop the looping as much, and you can check the thumbnail view to see when the CC3+ screen is showing correctly again. I spotted Ralf did exactly this on this week's livestream at one point, so I know it's not just me who finds this helps sometimes!
Marine Dungeon - further developments
And tides are not all the same either, so you tend to have a "highest recent" tide line of dead/stranded weed, shells, etc., which is often dry and/or rotting, and then the "latest" high tide line nearer the sea than that "highest" line. All that though assumes an Earth-like setting, which doesn't necessarily apply to all fantasy worlds.
Meanwhile, Atlantis, here we come!
