Ricko Hasche
Ricko Hasche
- Ricko Hasche
- 4,080
- Member
- 8,039
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 20
Snowy lands
My first completed map utilizing CC3+
@OwlishlyTaboo i have same perception of @Wyvern on #3.
When this situation happen to me - and is most part of the time, i adjust the proportion not by numbers but by visual (not zooming in), simple way: i select a mountain, hill etc already placed and compare with the new selected one.
When i get the "correct proportion" i continue mapping.
in last few weeks i start a new usual behaviour in those situations, i write on paper all main sizes (and color number used... plus you can add size/color records to background, medium ground and fore ground on map):
back ground middle ground (optional) fore ground (optional)
mountain : 0,5 color 35
hills : 0.4 color 37
tree : 0.35 XXX
city : XXXX XXX
This helps me remind fast witch size/color i use as base refference in a great size scenario.
Nice Work mate, keep on!
Cheers
Small Landscape - Newest Mr. Schley Art
- when i added edge stripe image appears on back ground, so ive added some mountinas on Symbol Back sheet to hide those back lines from the hidden land.
- not shure already what i like more in this example (i changed a little bit to make a test). i hidded the land behind the hils image, so only appears edge stripe effect (or not, then no need to place a hidden land)
- on this is the another option, make a very thin land line, just to give some green.
night landscape
