Royal Scribe
Royal Scribe
- Royal Scribe
- 9,531
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[WIP] The Mad Tea Party
[WIP] Community Atlas Competition - Artemisia - Spiros Isle - Aretizo village
Model Railroad track symbols?
This is a different approach than what you’re asking about, but possibly with the same end result: Remy did two tutorials showing how to construct rail tracks: Martian Mines and the Silver Mine.
[WIP] Greenwood Falls (CA211 Watabou City Revisted)
Yes, I did use the draw tools for the trees - worked great! For the river, I used "Change like draw tool" to change it to the 75-foot river. I also used the "Change like draw tool" for the sea (the straight closed polygon water tool), the three main roads, the round towers, the square gatehouse towers, the docks, the parks, and the buildings. I used the draw tools (but not the "Change like draw tools") for the city walls, the bridges, the trees, the darker grass beneath the trees directly to the south-east of the castle, the fields, the hedges, the dirt roads, the town square, and the forest on the north side of the map. For the heraldic symbol, I did as you advised, moving the components to the appropriate sheets and changing to a solid color. (Interestingly, the deer didn't fill in completely, just the outline.)
There were some minor issues that had to do with how Watabou exported the data. The river was in multiple sections, broken by the bridges, and the stretch between the final bridge and the sea wasn't there at all, so I did that part using the draw tools. The major road coming in from the west continued up the river a bit, so I had to trim off that part. Same with the road coming in from the south: it continued down the river from where I put the wooden bridge. So you just have to pay attention to what's being changed to make sure the right things are being changed properly, knowing that you might have to trim a bit here and there, or use the drawing tools to add a bit.
But overall, worked great! I am going to do a larger town now, and will time it to see how long it takes.
[WIP] Town of Kukaar (Ancient Cities Annual)
I've played with a few different options. Thought I could copy the Random Street buildings to a sheet below and then turn then into a gray polygon, but if there's a way to do that without it being a gray house, I haven't figured it out. Tried the colorize effect to mute the effects of the background. Of course, I could delete the background terrain and redraw it around the houses, like for backyards.
But I think, since it's such a small map, that I will just limit the Random Street houses to a few around the paved plaza, like they are specialty shops or government buildings, and then hand-place the rest with the buildings symbols.
