Quenten
Quenten
- Quenten
- 8,066
- Member
- 3,090
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
MY MUNDI IS READY!
FT3 to CC3+ as per recent Live Mapping Tutorial
I was really impressed with this video, as it has made things a lot easier for me to translate FT3 world to s CC3+ style I like. Thanks Ralf.
In my example below, I have decided to translate a FT3 section to a Pete Fenlon Style (revisited), but I have also used the rivers that were created in the FT3 map.
Here is the FT3 map:
Here is the translation to Pete Fenlon, and it was SO easy. Again, thanks Ralf.
Obviously not completed.
Here is an insert.
Egg Hunt!
Very Minor Interface Tweaks
First: When choosing Shaded Polygon by Edge in the Polygon drop down menu, it is a bit annoying to then have to type in editshading (if you even remember the command) in the command line - could editshading also be part of the dropdown menu?
Second: When choosing fractal polygon or polygon line, can a drop down menu option (ie right click) be added to edit the fractalise inputs.
Third: Could drop down menu (right click) on the erase button be added to just erase the top entity of the selection. Sometimes there are unintended duplicates. While I can deal with these by first clicking the top visual edit button, then Del then P, it would be so much quicker if I could just delete the top entity of the selection where I have had accidentally created multiple copies.
Finally, can the List command produce an output with about double the font size, and also perhaps a bigger window as well.
These are the most common procedures I use that would help a lot if put as drop down menus.
Assistance with Map Overview Export
I am interested in why you have had so much trouble doing this city, when i have done several cities far larger with less problem. I would be interested in why you have had this problem and I have not - is it because you are using vector symbols rather than pngs? What do other people think.
Here are the links to two bigger cities I did for the Atlas.
Browse Maps - Archesyne - ProFantasy Community Atlas (monsen.cc)
Browse Maps - Torstan - ProFantasy Community Atlas (monsen.cc)
