- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Too early for a CC4 wishlist thread, or is it timely?
The majority of us use a mouse because it's actually easier than using a drawing tablet. I have a perfectly good large Intuos Pro, but I never use it with CC3 because mouse is better.
However, I get what you are saying since there are users who cannot use a mouse, though I am out of my depth regarding any kind of alternatives - not being a coder myself.
Distance
Using Mike Schley symbols
Numbers Don't Appear on Dungeon Map
If you want to add number labels the easiest way is to add text labels using this button: |CC2TEXT|
A dialog will appear, into which you type your number and hit enter. Then the number should appear on your crosshairs to position wherever you want.
While the number is still on your crosshairs you can alter the alignment by hitting keyboard keys as follows:
Horizontal alignment:
- C = centre
- L = left
- R = right
Vertical alignment:
- M = middle
- T = top
- B = bottom
If the number is too large or small, before you place it hold down the CTRL key and move the mouse until it is the right size. Set your size with the first number and stick with that size.
EDIT: Also do as Steven suggests and check that your TEXT sheet is near the bottom of the list of Sheets and Effects.
Live Mapping - Dungeon Secrets.. Or Secret Dungeons?
Escarpment help needed
Expanding Endless Sea of Ice FR
How Can I Draw Real-World Places in Campaign Cartographer?
It sounds like you need a hex style where the hexes are ready-built to be placed on a snapping grid, though that might mean the coastlines, rivers, and boundaries, etc. are more hex shaped than you would probably like them to be.
Perhaps something like Hex Overland? It's in the same Cartographer's Annual as the last example I showed you - the 2010 annual, or "Volume 4".
These are the symbols from that style.
There are a number of hex mapping styles that might suit, but do you need to limit yourself to actual hexes or will a hex grid do? CC3+ can add a numbered hex grid to any map, like this (the map below is one of the example maps from the style Modern Political in the 2010 Cartographer's Annual).
Original map (no grid)
The same map with a grid I just added.
As I said above, you could use any style you liked if a hex grid was an acceptable alternative to hex components, or even make your own style as Mike has done.
If you want to have a look at other styles available there's a page of links here.
As for the actual drawing of the map - the coastline etc, you can import image files of these types into CC3+ and trace the shapes as you wish.
Lost fills
