- Loopysue
- 9,992
- Member, ProFantasy
- 9,868
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Issue 199
Interesting. Mine shuts straight away, but I do have the same pdf opening issue as you, Wyvern.
I use Acrobat Reader, which at first sight appeared to fail to open. But when I tried to open Acrobat with an unrelated pdf it failed to open again. I checked the Task Manager and discovered the relevant number of Acrobat processes were actually running. There just weren't any Acrobat windows showing and no indication in the Start bar that it was open.
(to open Task Manager press CTRL+ALT+DEL and pick Task Manager from the list)
I ended the Acrobat tasks by right clicking each one and picking End Task, then Acrobat opened normally, though of course not from the installer since that had already closed at the end of it's process.
Issue 199
Live Mapping: Monkey Frog Overland
Hi everyone! :D
Tomorrow, Ralf will be taking a look at the latest Cartographer's Annual issue: The Monkey Frog Overland style.
Come join us on YouTube for the live chat here:
https://www.youtube.com/watch?v=FRFdjZcJU3w
Or see it right here on the forum if you prefer.
We would love to see you there :)
how do you extend the white border
converting polys fractal to smooth?
Yes, that's very true.
@HelenAA - Joe's recommendation will also prevent the 'fly away' artefacts you can sometimes get when smooth nodes are more or less on top of one another, for example when converting a more extreme fractal line or polygon.
Would anyone like to colourize some B&W maps from PDFs for me?
Hi alloowishus :)
CC3 is a vector-based app and and can't edit bitmaps, even though it produces them as an output end result.
There are a few mappers and artists here who also use bitmap editors like PS and Affinity or Krita, but if you are looking for somewhere with an abundance of artists who work with bitmap apps and who are also quite conveniently for you looking for work you might like to try asking the same question at the Cartographer's Guild.
This is the "Mapmaking Requests" subforum.
Wall Mural Symbol
my Tunnels and Trolls world so far
Overland Template Suggestions - Continent Scale
The wall of links that Jim mentioned above is here:
conflict with explorer.exe during setup
