Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
Community Atlas - Berenur - Temple of Aeniar
@Monsen Remy I found an issue with the text so I fixed it and here is the new .FCW file. Also added a glow to the puffin.
After seeing map in Blog found another text error missing stables - corrected and re-uploaded.
marble tile floor textures available?
Full Installation Almost Complete. I just need...
Links can be found here.
https://forum.profantasy.com/discussion/10443/free-symbols-artwork#latest
Mike Schley freebies
(WIP) Bindak's Retreat - An Asian Pirate Hideout
@JulianDracos Not strange at all. Where I live you see forest or heavy vegetation between barren hills in the valleys. It all has to do with latitude, weather, terrain elevation, tree line elevation, soils types etc. ie a lot of factors.
@EukalyptusNow Really nice map/ Love the fish heads
Winter Trail Project
My problem with the rocks is that the snow on the rock is too flat no texture, That would be fine if the ground cover was also completely covered in snow but that is not the case. There should be more texture in the snow on the rocks and the larger rocks need some of the rock showing through the snow more to match the other ground terrain objects.
Looking forward to this set of symbols but in real life I'm soooo tired of SNOW!!
Catalogue symbols are all red crosses
Beware you may have other issues if you are using a remote (active backup) drive when using CC3+ the syncing can cause you additional issue with the program, because when your Google Drive sees a change it will sync the file. Recommend you pick up an external drive as they are pretty cheap these days.
I have the data drive on my D: drive and have a folder for my active and archive files I'm working also on the D: drive.
Print Issue
Upside down text on a curve
What I have found in the past is that how the curve/line is drawn affects this. Ie right to left / left to right / top to bottom or bottom to top. It seems that the programs takes that information and then the click point of where you selected the curve/line along with the option you selected in the dialog to determine how to draw the text. I did sample tests and then made sure I also drew the line/curve using the correct starting point I needed to get the text ithe way I wanted it displayed
[WIP] Atlas Contest : Ingensteds Village, Seal Island, Alarius
Thank You
I'll work on the shadows but I should also darken the global sunlight as there would be little to none this time of year. Maybe I need some fires set out for lighting.
Based on where the island is and the location of the village I think it's above the tree line (too far North) so I was not going to add any trees or bushes.
I do live in an area that cold but far enough south to have trees.
