3,153
Member
5,382
24
  • [WIP] August Competition - Vertshusen Town Hall and Tax Office
    Anyone else feel odd doing a "Like" for the tax office? ๐Ÿ˜‰
    Loopysueroflo1
  • [WIP] Community Atlas August Mapping Contest: Cloven House
    More time today, and first-off, I checked the On New Macro as well as the On Open one, as I was fairly sure when I started the new file for this map, the Simple symbols set had indeed loaded. Which is where I discovered this was indeed the case, and that the correct CATALOG line should be :
    @Symbols\Modern\Floorplans\Dracula Dossier\Simple.FSC
    and not:
    @Symbols\Modern\Floorplans\Dracula_Symbols.FSC.
    The macro's easy enough to change in an existing map file drawn in this style using the edit facility. You can open it from the Drawing Properties icon on the top toolbar |CC2PRESETS| via "Settings - Map Notes", which brings up the "Select Note" pane.
    Choose "OnNewMacro" and click "Edit", from where you can copy the last typed line with the correct location for the Dracula Dossier "Simple" symbols catalogue file.
    Close the OnNewMacro without making any changes, and open the OnOpenMacro one the same way, then simply paste the copied text line over the last typed line there to correct it.
    Before clicking "OK" to close the macro edit pane, make sure there is ONLY ONE BLANK LINE immediately below the typed line you've just replaced (try to move your cursor further down using the arrow key). If there is more than one, delete it, as if there's anything other than a single blank line there, the macro will become confused and sulk mightily at you! (That is, it won't work properly; note there MUST be one blank line there, however.)
    Then save the file. You can check it's working by closing the file you've just saved and reopening it, where the 10 items in the Simple catalogue should now be showing in the symbols catalogue panel to the left of your drawing window in CC3+.
  • Forest Trail project - part 1
    So, no need to be stumped by all the trees in a battlemap any more ๐Ÿ˜
    LoopysueJimP
  • And another small map, this time in SS2 / CSUAC2
    The tents look rather flat, very pale and a bit "ghostly" by contrast to many of the other symbols. Might be worth rethinking their use here?
    Also, the bridge shadow seems to be at a different angle to all the others in the map (presumably because this has been drawn as a separate "shadow" polygon).
    Daniel Pereda De Pablo
  • my quick ice bit CA189, not a cavern though
    Yeah, I think it's a lack of the right Sheet Effects Jim. Try looking at the Winterbourne Langton sample FCW that comes with the Winter Village pack, and see how the narrow footpaths have been done there (on the ROADS Sheet). Those are a near analogue to what I was thinking of here.
    For the final wolf tracks, however, you might need to be creative, and draw some suitable polygons to get the look right for footprints dragging through the snow at this scale, rather than using drawn lines. Try playing around with the Effects first though.
    I can't offer a great deal more precisely, as the wolves are showing up as rectangular red Xs for me on the FCW. I thought I'd reloaded all this free stuff a while ago, but I got a number of red Xs on Quenten's Vertshusen city map for the recent mapping contest too, so I must have missed some stuff. I've never used these non-PF symbols though, so it's not really worthwhile my going through the involved rigmarole to try to load them all up again. Sorry!
  • Style Request: East Asian Floorplan/Dungeon
    I was actually thinking more about the topic title than what the style might contain, Sue, in case someone's trying a search in future for something for elsewhere in East Asia than Japan.
  • Smirnoff Castle
    ...I would have to start from scratch again - since the map of this drawing - as I did in a "descriptive" way - I didn't use scales so I don't have measurements.
    That's a shame, if understandable. Maybe something for the future, with a different castle, perhaps?
    Ricko
  • Community Atlas - Berenur - Urtrah Desert
    ...about the grid in this same image, grid are above all except symbols and text layer as you can see in ftw.
    Actually, I wasn't talking about the grid at all, but the scalebar, which is still more or less unreadable, because it's set on top of the mountains. If it was placed on the plain-texture open land, it would be easier to read, to see how it relates to the grid size.
    When you're using a grid like this, it's really important that the scalebar shows what size the grid is, especially because the grid isn't covering the whole map. This is difficult to tell currently also on both the Zaras Lake and Jibarut maps.
    And on the same topic still, the As Sutat map needs some sort of scale adding!
    On this As Sutat map as well, there seem to be several flat animals in the NE quarter, towards the lower left of the "Al Diqaq" label. They probably need some shadows adding, I think. Unless of course they really are meant to be flat to the surface - the carpet sheep of As Sutat, perhaps? ๐Ÿ˜‰
    They're good looking maps, don't get me wrong; they just need a little tweaking here and there ๐Ÿ˜Š
    RickoJimP
  • Shadows of Yog-Sothoth
    I don't know what price point Chaosium will put on the revised and expanded Shadows. It isn't as big a campaign as Masks or Orient Express, so it won't be as much as those other big books.
    But if the H P Lovecraft Historical Society do another boxed set of props to go with it... ๐Ÿ˜๐Ÿค‘
    ScottAjmabbott
    Do I keep the non-mossy ones now I've figured out how to do the mossy ones?
    Of course, Sue.
    You should never ask the Internet and expect anything other than a resounding "Yes" to any question though ๐Ÿ˜
    LoopysueJimP
