Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Community Atlas 500th map and 4 year anniversary competition with prizes.
With the document, I'm not sure what to do. It won't work properly just in a .txt document. I've seen other people with longer writeups, so I'm wondering how we go about that?
The issue here is that all notes go into map notes in the map file itself, and those doesn't support anything but plain text, that's why it has to be a plain text document, no formatting, no tables, and no images. I can post a prettified version on the website, since that is a .pdf, but it is important that no content should be lost by reading the text-only version in the map notes.
Community Atlas 500th Map Voting Thread - Please vote
Community Atlas 500th Map Competition Results
New here: Cave walls
DD3 uses a different style here, if you turn on effects, it uses a glow effect to outline the edges and give an illusion of depth. After all, caves doesn't relay have walls, the walls are just the edge of the masses around the cave.
But if you really want separate walls, the easiest way to do it is to copy the floor polygon to the walls sheet, then use :CC2MCHANGE: on that copy, and in the dialog change the layer to WALLS, change the line width to the desired with of your wall and change the fill style to your desired fill.
Community Atlas - Elen Daelarion - Thrarasie Faire Cave, 14 & Western Hill Fort, 16
And today @BlackYeti's entry has been processed and included in the atlas. Thanks for participating.
What is your favorite annual?
Forum oddities in recent days
The most important thing for me right now, is this causing any problems (except from seeing an annoying error message)? I think I did manage to get it to stop reloading the page in the middle of writing a comment which could lead to data loss. While seeing that error every so often is annoying, what I really need to know is if situations arise where things like comments are actually lost.
And thanks for the idea Jim, but no, this isn't caused by an old address/url.
