Ricko Hasche
Ricko Hasche
- Ricko Hasche
- 4,086
- Member
- 8,039
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 20
Ukbur Valley
Hey @Calibre After entering the rule of three, another resource that must be studied and understood is the leading lines. It adds a lot to the composition and works closely with the rule of thirds.
Mastering the leading lines in your composition adds a lot of "dramatic" appeal to the scene. Whether in video, photography or even map composition. In the example above it refers to the yellow lines.
This article is interesting as a first step.
Cheers
Looking for an isometric stable symbol.. is there one?
Battlemap collection for personal use
[WIP] Spectrum Overland Waterfalls x 2
Sometimes, it is possible to make lakes and waterways with a little patience when fitting images of hills and mountains.
Spectrum Overland has sharper and more interesting shadows than Mike Schley for example, but on the other hand, it is very difficult to invert the images to have more possibilities of varying the scenery.
New Mike Schley Glaciars Content
@Royal Scribe for the glow behind the volcano I created two sheets for use with planet symbols and used two planet images one in each sheet (to emit a round glow).
A planet with an orange outter glow with more blur and Another planet with the red outter glow with less blur (smaller radius sphere). The only mike schley isometric symbols are the market stalls, the statue and the rowboats near the bridge, all others are from overland.
Maybe this little tut is some help for you. (ive made others using mike schley also)
Cheers
Sheet Effects stop working consistently
@Lee Talman you can create as many sheet terrain/land features or even sea as you want. I frequently use this feature to be able to superimpose effects. In this image you can see 3 new sheets: 2 of land effects (the ice is on top of the tundra, and the SEA LAKE to produce the lakes on the map using the "water" of the sea.
You can also calibrate the inner opacity (I usually use between 40 to 80%) so as not to have a "too harsh" effect, sometimes even with low opacity the effects can mix, sometimes causing a desired effect - there is no reference rule for me, I adjust as I go.
Once your new sheets are created, and when you select the new terrain/land features effect... sometimes the program "sends" you to the original sheet, so you need to check and sometimes change to the desired sheet. However, even doing this, sometimes it happens to me that the program insists and places "base" terrain/land features on the sheet.
So what you need to do is go to the "change features" button, select the effect and click ok, then you choose which sheet you want to send it to. Normally this selection is easier when "activate sheet effects" is turned off, because the edge is easy to select, when edge fade inner is activated, it is usually difficult for me to select the TERRAin sheet I want.
Cheers
Spider Attack!
Hy @Loopysue thanks!
Using Adobe Lightroom, above and below I used graduated filter to darken by lowering the exposure.
in the middle - the mill and in some houses I used the radial filter to increase the exposure and "draw attention" to the buildings.
in the end, I increased the shadows in the corners using circular vignette.
Total beginner who is strugling to find the correct tutorial
https://www.youtube.com/watch?v=B8Fvz98lJ7Q&t=201s
Maybe this video will help something. For me, he was absolutely essential.
How long have you been using Campaign Cartographer?
June 2011, Tired of drawing maps by hand since 1989 when I started playing at 12 years old, I thought: - it's not possible that there isn't a specific program for that...
After asking Saint Google, I found CC3 and my world was about to change... At the end of July I moved from my home country, and arrived in another country with just a backpack on my back. Without a computer and in need, CC3 was obviously far from my priorities.
Time passed and my difficulties became fewer. I had a computer and I felt a deep desire to draw again. Searching the page again, I saw that it had a lifetime guarantee... how wonderful! September 2021I installed the program again and here we are today.
New user from the Netherlands, nice to meet you all!
