Ricko
Ricko
- Ricko
- 6,731
- Member
- 10,564
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
Battleground Cimitery A3 80 x 55 👻
issue exporting
When program is on and sheet effects on, problem dont appear
but when i export - using config @Loopysue gimme on lasts post, appear those lines and cant know where they come.
Thanks
issue exporting
Battlemap House of a retired adventurer.
- look between bed and bear carpet on flor, maybe have a escape route there...
- totally forgotten thanks
- dont know the icon to connect both, but of course the use active coal to one or another, moving with a shovel between them.
- the nights are long, cold and lonesome. if you see... is stock of wine and food are also plenty full... maybe winter is coming :D
issue with font
i was typping my map names, and noted this 2 names like as "double".
went to tect sheet to look if i had typed 2 times same name in same place and dont... also all other 32 names was ok.
this appear in opened cc3+ also when i exported (this image is from exported map) in both - jpg and png
someone can help me with a light why this happen? thanks
issue with font
issue with font
Ushuaia - End od the World - Land of Fire
Initially Ithought in make solid road on map...
but after i realize that Ushuaia was almost impossible to reach by land until around 1950... so was a perfect place for Argentina make a big prision there, cause escape was almost imposible. They have some historys from people who jailbreak and after they realize they was alone in a very cold place... they bagged to return to prision to survive.
based in this, i make the option to select the small road with dashed line, as indicator of a very very smal road....
But i understand your tip. Thank you.
fifth map
The beauty of (fake) Colli Euganei. A new WIP.
