Ricko
Ricko
- Ricko
- 6,740
- Member
- 10,565
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
Issues with Inked Ruins Style: Hatching "Texture" Size and Water Rendering
A Temple and Market Square Battlemap
@EukalyptusNow Note that in the 2 large tree below (the only ones in Symbols TREES SHEET) I added a slight transparency effect (85%) enough to allow you to see the temple fence below.
The Temple of Hekaria - a Dungeons of Schley Battlemap
I typically use multiple TERRAIN overlays on floors whether they be dirt, grass, bricks, rocks, etc.
I just select a color similar to some other bitmap fill from TERRAIN to, on the one hand, break with the visual repetition of the Bitmap on a large scale, as well... for example in the wood of the inn - where a lighter TERRAIN (in this case I think it was earth or mud) which shows - in the most traveled places the effect of wear and tear. I have even used some Sheets (created) including on top of SYMBOLS.
For these effects, I normally use EDGE FADE INNER between 40 to 90% and with a lot of Edge Width proportional to the size of the map.
Here an Example
Cheers
Battlemap collection for personal use
Hy @Steven Nentwig (Steven!) the cliffs are from @Loopysue city cliffs
One night of fun - A mini dungeon with that ends with a dilema
@EdE If you want to place the grid only on the inside of the drawing, this tutorial that Sue did for us is extremely simple and useful.
almost the same
