EukalyptusNow
EukalyptusNow
- EukalyptusNow
- 660
- Member
- 1,241
- Germany
- Surveyor
- 8
Reactions
(WIP) Bindak's Retreat - An Asian Pirate Hideout
Thank you for the comments.
Yes, there's barren hills, but I'm simply not yet finished with the right side (WIP ๐ ). Still undecided whether I'll add more vegetation, bits of different ground texture or bits of both. It'll probably be rockier than the Western plateau. Will also add cave entrances to where the paths end.
The blue green Terrain is supposed to be swamp/ water. A bit of terrain where the ground is more level and the ground more water absorbent, so it catches the rain running down the slope to the North. I'm thinking about moving it a bit more North / downhill now, where it would collect more water running down the slope.
The roof damage effect is rather easy:
Add a colour Key effect to the appropriate building sheets, and then put floors, rubble, beams etc beneath it.
@Loopysue found it and created a great tutorial about it (This seems to work only on city symbols, which is a bit of a shame.)
Edit: Just tried it out with SS6. Doesn't work there. ๐
Gioiella, a small Serpentine City map
No. Had to create the ring in a rather elaborate way:
- Build another land mass using the land mass tools.
- Copy the settings of the land mass.
- Manually set a with
- Draw a ring shape using the circle drawing tool.
- Open the sheet effects and put a colour key on the land sheet (as topmost effect).
- Draw cutouts and manually "rough up" the inside of the ring using colour key fractal polygons.
- Manually draw the coast lines of the new land masses on the coastline sheet.
There's probably easier ways of doing this (trace command?), but that was the way that came to my mind. Does anyone know an easier method?
Drabarmund - an SS5 village
Carn Dum - using Inked Ruins annual
Cursed Junction
Bridgetown - An SS6 experiment.
A2 Forest Trail - Ruin Tower Battlemap
Pirate Attack! A quick Battlemap
The Altharan Peninsula - a quick map using the Mercator Annual style
Very nice map. I've thought about creating a map in the Mercator style for a while, but never really gotten to try it.
The coloured names are a great addition. They look good and make the names of the main city states stand out, so they improve style and purpose. :)
I might play around with the city state colours a bit more - maybe try some "warmer" colours like dark yellow or orange instead of the cyan or purple, but that's more a matter of personal preferrence and not of "better" or "worse".
