How to get add-ons to SS4
Hi!
How can I get more symbols to the dungeons of schley add-on.
I have installed the SS2 and it doesn't give up any symbols to the SS4.
Example, I need a furnace.
Any clue where could I find furnace symbol?
Hi!
No matter what map style you are mapping, you can always access the symbol catalogs from the other styles by opening the symbol catalogs manually using Open Symbol Catalog
Or, you can switch the style temporarily to for example the SS2 style by loading in one of the SS2 filters by right clicking Symbol Style Toggle
and picking the Master Filter option. From this dialog, hit Load, and find the SS2 setting in the list and load it. Now, the symbol catalog buttons at the top will load SS2 catalogs instead.
Of course, SS2 is a different style than SS4, so you have to judge if they fit with your MS map, and which set (A or B) fits best, if any.
Sorry, but can you show me where the "Open Symbol Catalog" is?
Maby with a picture or something.
Just above your symbols:
It will look wider if you have two or more columns:
Thanks for helping me, but can I get a furnace symbol from anywhere?
If you can't find what you want in all the CC3 assets you have, you can always import third party assets. There's a list of commonly used ones here:
https://forum.profantasy.com/discussion/10443/free-symbols-artwork
I can't say which of them, if any, will have a furnace in them, but other people might be able to help you there.
Not sure.. Every style comes with different symbols.
I haven't installed the SS addons on this machine, so I'd have to check later. I did find, however, Stoves and Fireplaces in the Naomi VanDoren furniture catalog:
What you can do is open up
ProgramData\Profantasy\CC3Plus\Symbols
in Windows Explorer and use the search function in the top right for any keywords you're looking for.Once you find something you like, it's a matter of opening the catalogs for that style (most likely in "Furniture.FSC", but maybe not) to see if it fits what you're looking for.
Hope this helps.
After installing the Dundjini and Vintyri symbolf from the article mentioned above I found furnaces under the shield symbol: "CSUAC/DA Equipment" under the subsection "Tools, Smithy"
