Missing Assets
For some weird reason, I am all of a sudden missing assets and I cannot explain why. The screenshot shows missing Mike Schley graphics, but this anomaly isn't limited to that artwork. I have completely uninstalled and reinstalled CC3+ and Update21, yet the problem persists. Has anyone encountered this and resolved the issue?
Does this happen in every map, for example, does it happen if you start a brand new Mike Schley map? (And does it happen with other map types?). If it does indeed happen in a brand new map, can you try to open up the fills tyle dialog in that new map, go to the bitmap files tab, select a missing fill, for example Desert_MS and check the file path listed the. Then check if that file actually exists on the disk (The @ symbol refers to the CC3+ data directory, usually c:\ProgramData\ProFantasy\CC3Plus)
All the .dll files for the effects are found in C:\Program Files (x86)\ProFantasy\CC3Plus\Filters, you can always check that they are actually there (should be 9 files)
You could also try to check that the visual C++ runtimes required by CC3+ are properly installed. Normally, these are installed automatically by the installer, but you can also download them directly from Microsoft and install them manually, you'll need both the 2017 and 2013 version of the redistributable, found at this page. Note that you'll need the x86 (32-bit) version of these, no matter if your Windows version is 32 or 64 bit.
If that doesn't help, I recommend you contact Technical Support, they should be able to help you get this sorted.
Thanks for all your help!
Could this be related?
I cured my problem by re-exporting the map and starting again, but I'm not the one trying to save a map that's been going for several decades!
If this has just started to happen, and since there hasn't been a recent update, I might suspect MS Windows updates.
In fact I do most seriously consider MS Window updates to be the culprit!
Well, it's either that or we all caught a PC virus aimed at CC3 at roughly the same time, and I don't think I've ever heard of such a thing. Plus we all use different AV.
I follow an advice that I found here in the forum
Topic can't load CC3+
In short:
Run a DD3 repair install
and I usually run a reinstall of Update 21 - the last CC3+ update.
Then everything seems to work properly again.
I had "the effect-error" quite a lot of times during the last months. It is a little bit annoying and I usually have it on my Win 10 pc, not on my old Win 7 one.
