help with trace
I'm trying to follow along the sweeney tutorial video, and he gets to the point of tracing the coastline with his mountains. All good, hit the coast, move the cursor, it does follow the coast... come back inland, close off the polygon and hit right click... fills everything OUTSIDE the polgyon and not inside?
Wtf?
what am i doing wrong?
That means you are picking the polygon in the wrong spot when you pick the polygon to trace. The spot you use to pick it is very important, as the trace line will always go through that point, so it needs to be on the section you intend to trace.
More here.
Make sure that when you pick the coast to trace it you are picking it between the two points you want to trace along it. If you pick outside that part the trace will go all the way around the coast the other way and result in this inside out tracing.
Ninjaed each other again.
Yep. LOL!
