ChkData DAV Error
I'm getting the error messege ChkData DAV has not pending DRQ MENUDM #fcw32.mnu when I try and open one one of the es-tutorial maps. I'll get 2 select symbol boxes. The first is blank. The program crashes after that. several similar maps to the ES-Tutorial ones are in the Examples/UserGuide Folder that have the title CC3 First_Map. These similar maps don't crash the program.
I'm using Windows 7 and followed the Vista install instructions.
Wht do I do to fix this bug? I did install as an adminisstrator and applied Update 8 as the Vista instruction suggested, once after installing CC3 and again after installing the other ProFantasy add ons.
Help.
Help.
Hope that helps, Ralf
So any ideas what is going on?
somehow the OnOpenMacro in the ES Tutorial maps seem to misbehave sometimes. You can fix the issue by opening the "Drawing Properties" from the File menu, clicking "Map Notes" and deleting the "OnOpenMacro" note. Then save the map.
I'll put in on the list of things to fix here.
Also, after I ran Update 8 the LO and VL meadows bitmaps in CC3/Bitmaps/Tiles/Overland are messed up. I did find on the forum the fixed versions you posted. So anytime I run Update 8 I have to go replace those bitmaps with the fixed ones.
Profantasy has apparently compiled the patch with corrupt versions of these files and they overwrite the old ones. I'm installing it on another system and going to move the files over. But this is a mistake that Profantasy needs to correct in the patch.
I just installed the software today and I'm getting this issue as well.
I've tried all of the suggestions above and nothing I do will allow ES-Tutorial03.fcw to load.
I even uninstalled everything and reinstalled from the beginning without any success.
When the bug occurs, if I hit the cancel button for all the symbol set selection dialogues, eventually it dumps me back to the drawing without crashing out of CC3. I can then pull up File->Drawing Properties, click on Map Notes, click on OnOpenMacro, then Delete. Save the file, close out CC3, reopen it, no more crashing.
